Case Mod - In Progress [project] Apple Cube - final photos !!
Discussion in 'Project Logs' started by thegyufi, 5 Mar 2012.
  1. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    One good news for me : a new sponsor join my project :D :rock:
    - Linitx also join my project by sending me a great picoPSU with an AC/DC adapter.
    Thansk a lot Chris for all your advice ! (If you want to create your own tiny computer or your car pc, this is THE adress :rock:)
    please visit : www.linitx.com
    More progress soon on the slim slot-in bracket ... :dremel:
  2. thegyufi
    21 Mar 2011
    Here we are !
    Bit-tech, I show you my new slim slot-in bracket,
    My slim slot-in bracket, I show you Bi-tech, say hello :lol:
    The place where the dvd must be to keep the same original hole on the case.
    For him, I use 15.5x15.5 corner that i folded
    then I cut a piece of 5mm thick
    drilling
    tapping
    assembly
    I make some scratches to help the glue
  3. thegyufi
    21 Mar 2011
    The finition :
    (never thrown in the trash the screw of your vga card stock cooler :) )
    Some cutting
    set up in the cube
    cutting for the eject button, to let the slot-in entirely pressed against the top
    that's it !
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    This is turning out to be a very nice mod! Keep up the good work.
  5. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    :D Liking where this is going.
  6. neilhart
    neilhart What's a Dremel?
    2 Feb 2011
  7. thegyufi
    21 Mar 2011
    Thansk neilhart, I appreciate your message and your cube too !
    This is the exemple that we can imagine many different integration on this tiny cube. My choice was to stay with a "normal" hardware, as that I can upgrade when I want with less problems about the compatibility with the empty space in the cube.
    My package from Linitx was dispatched today !! Go fast delivery man !!
  8. jprykov
    jprykov What's a Dremel?
    29 Oct 2010
    This project is so AWESOME!!! more updates please :)
  9. thegyufi
    21 Mar 2011
    I do my best! But I know I'm not the fastest :baby:
  10. daverobson08
    daverobson08 What's a Dremel?
    21 May 2011
    I can absolutely recommend LinITX. Fast delivery and very helpful when it came to email support.
  11. thegyufi
    21 Mar 2011
    @daverobson08: I'm totaly agree, Chris knows of what he speaks :thumb:
    little progress on the bottom of the frame : there is nothing anymore !
    drawing
    cutting
    and after few hours of filing
    Don't worry, painting is planned :D
    This evening after work I'll go (again) try to find some honeycomb grills to put on this openings.
    If anyone knows where I can find it, please tell me !
  12. Atomic
    Atomic Gerwaff
    6 May 2002
    Super clean cutting! After some paint they will look like they came that way from apple.
    Try car modifying places as it's often used for custom radiator grills.
  13. thegyufi
    21 Mar 2011
    @Atomic, thanks for your advice, this is no stupid bu unfortunatly I don't have this sort of store near me !
    I just pass an order to mnpctech.com, why bill is he so far ?!
    Hope to receive the mesh next week !
    Miss you bill, near me... (commercially I precise)
  14. thegyufi
    21 Mar 2011
    little preview ... (packages received !) :clap:
    to be continued ...
  15. thegyufi
    21 Mar 2011
    Here is the first package from Prolimatech
    Unpacking !!
    we can see on this picture, the Samuel 17, a Blue Vortex 12cm LED fan, 3 little bags of PK-1 thermal paste and a little goodie for the phone :)
    the bundle fan : an ULNA, a molex 4 pins power adapater, some fixation screws and ... the fan :hehe:
    the fan seems to be of good quality
    the Samuel 17 :
    a complete bundle to be install on many sockets.
    Again a BIG Thank You them
    www.prolimatech.com
  16. KidMod-Southpaw
    28 Sep 2010
    Looking good!
  17. thegyufi
    21 Mar 2011
    and now the package from LinITX :clap:
    we can notice that the package is done with care :thumb:
    :eeek:
    the content: a picoPSU 160XT, an AC/DC Adapter 150w + her french plug (well done ;) ) and one PCI Express X16 Flexi Riser Card.
    A closer look of the riser :
    He is shielded, and seems to be of very good quality
    (link LinITX : http://linitx.com/product/10881 )
    the group who gonna manage the power
    (link LinITX of the AC/DC Adapter : http://linitx.com/product/12342 )
    A closer look of the picoPSU 160W:
    (link LinITX : http://linitx.com/product/12914 )
    I will post some other pictures when I've done the assembly.
    I already tell you a hundred times Chris, but again Thanks You for everythings !
  18. bruce_rob
    bruce_rob What's a Dremel?
    18 Apr 2010
    quality PSU mate i think im going to get one
  19. thegyufi
    21 Mar 2011
    go my friend, and tell to Chris that you come from me ;)
  20. thegyufi
    21 Mar 2011
    little progression :
    I don't want this holes any more !
    "voila"
    My new Gigabyte GT520
    fanless !
    which will be installed like that
    So need to make a little cut on the chassis to slide the riser inside him
    And the config installed with the Samuel 17 and supplying by the picoPSU :D
