lol for me if you have time, you can't have anything except a good result ! Some photos of the new hardware : I'll remove the fan to be fanless after, the time for me to make some test before. I'm happy because the blue of the mb is almost the same blue of the ssd/ram HyperX
lol Ok, some news : Has I receive the mesh from mnpctech, I make some progress with her : Petite avancée : creation of a paper template ok, I think it's correct, so go on the mesh ! the paper template is really helpfull to know where I must cut ! the bend with 3 corners and for the round bend, I use an evactuation pipe epoxy's gluing and after drying Voila, normally I'll post some other news tomorrow Bye
please don't stop to comment it gives me courage ! Ok here is the big up announced yesterday, about the pci slot and the I/O panel First the pci slot : drawing : cutting : bend and tapping for the pci fixation : on the other side of the pci slot, to keep the card in her place I use a little plate Just gluing : That's it for the inside of the slot, now the outside drawing again : cutting (again) : filling (yes again) : and the gluing (now together : ... ) a little preview with the mb and gc Voila ! The next news will be about the picoPSU which need to be a little shift to keep all the cable inside the chassis. See you soon !!
If the scratches are not too deep you can polish/ buff them out using toothpaste. The abrasive action polishes out the scratches from the old plastic Mac cases. I used toothpaste to polish my iBook and it came out nice and shiny and only the deepest scratches remained Other products such as glass polish or Brasso (metal polish) are also known to work, but perhaps test them on a scrap piece first.
Thanks for your advices, the products you mention above "glass polish or Brasso ", can I find them in a car shop ? I will test this, but yet I'm not sure to really want conserve the original design of the case ! Will see !
