Project Fibonacci Sequence
Discussion in 'Project Logs' started by Pfaffen, 5 Jun 2007.
  1. Xlixen
    Xlixen What's a Dremel?
    16 Apr 2007
    Nice idea, and good skills. Keep up the excellent work. cant wait to see the outcome!
  2. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    wow that looks great!
  3. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    Plexiglass
    I went to Home Depot and bought 4 pieces of plexiglass. They were 24x18. [​IMG]
    Once they were cut to size, I needed to clip the corners. I first put them together and did this by hand...
    Here is a close up...
    And the finished hand cuts...
    But that was too time consuming. So I made a few adjustments to the table saw and cut the corners on it.
    Here is a shot of the case with the 3 sides put in. I still have to build the access door for the last side.
    Here are the models for the Power supply unit, DVD and 80mm fan.
    Here is a close up of the fan.
    The next step is to cut the holes for all the computer components.
    I'll start with drilling the holes for the motherboard. The trick to drill holes in plexiglass is to go slow, about 200 rpm max and take your time. There is nothing worse than cracking the plexi.
    Next would be the holes for the fans, IO devices.
    More to come...
  4. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    looking good!!! nice to see so many wood cases atm!!!:thumb:
  5. wbdog206
    wbdog206 not me
    15 Jan 2007
    coming together nicely. nice work.
  6. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    This project is looking very good.
  7. Pfaffen
    18 Mar 2007
    Layout lines
    Here are a few shots of the lay out lines for the front.
    They will be walnut as well. The plexiglass will be covered in gold leaf.
    Still trying to decide where and what color to put lights on this thing. It will be in the living room near the TV, so everyone will see it and I don't want a lot of lights blinking, when the hard drive is moving. Probably just a single power light on the front, along or as the power button.
    The gold leaf will be a little tricky, I've already done some samples... will have to take a few pictures... I'm not sure if I want the highly reflective look or the older "weathered" look.
    More to follow...
  8. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Looking nice, have some stars :)
  9. dacust
    dacust What's a Dremel?
    10 Mar 2007
    Weathered. After all, the Fibonacci sequence IS rather old.
    Seriously, it could look good either way. I figure that's one of those things that only you can decide since you see it in RL and have the vision in your head. In my imperfect vision from a distance, I think weathered would look better.
  10. Pfaffen
    18 Mar 2007
    I'll take some shots of the test pieces and let you see what I'm talking about. I'm partial to the weathered look, since, as you said, he is old and the time it would take to burnish all the sides, well... it would be a lot.
  11. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    wow you have really made great progress
    looking great
  12. Pfaffen
    18 Mar 2007
    Couple of test pieces
    Here are a couple of test pieces. Although they look a little like brass, they really are gold.
    This is the first one I did, just sprayed the adhesive on, let it dry and then added the gold leaf... Not what I orginally expected but it was fun to practice.
    With this one I took more time and smoothed out the surface... Still not the shiny look, but getting closer.
    Lastly, this on I wanted to see if I could tape off areas and still get the effect I wanted. Not sure on the outcome...
    Here is a blurry shot, but it shows more of the gold color.
  13. dacust
    10 Mar 2007
    Wow. All three of those look good.
  14. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    hmm imo the middle (round) one looks best...good work!
  15. Zero_Limits
    Zero_Limits Minimodder
    18 Apr 2006
    The title of this project gave me flash backs of high school.
    As for the actual case, WOW! amazing skills and quality workmanship!
    I also think the middle one looks best.
  16. Frido
    Frido Minimodder
    19 Apr 2007
    Middle one too! Got the half-weathered look in a genuine way imo. Superior craftsmanship, wish I had your skills!
    Good luck with the project, I'm eagerly following it!
    /Frido
  17. Pfaffen
    18 Mar 2007
    Jig
    I had to make a jig to cut the slots for the top and the bottom.
    Here it is. I had some scrap pine around and made up this simple jig.
    The rails go in the slot in the middle and are held in place by the walnut stops.
    Here is a shot of the four top rails routed out.
    And here is my router...
    Lastly, here is the finished top.
  18. Pfaffen
    18 Mar 2007
    Thanks... I tend to like the middle one as well...
  19. Pfaffen
    18 Mar 2007
    Thanks... and there will be more to follow. I just finished to top and bottoms today. I may be able to get the pix on later tonight, otherwise tomorrow.
  20. Pfaffen
    18 Mar 2007
    Thank you very much...
