Case Mod - In Progress Project M8 (CaseLabs M8 workstation mod) COMPLETED! Final pics on page 33
Discussion in 'Project Logs' started by p0Pe, 13 Apr 2011.
  1. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    I love those stands buddy!! As an ex metal worker I have the same worries as my friend Angel (same name too!). Aluminum welding isnt the way to go in that case as its almost impossible to come up with good results. Tiny screws perhaps???
    yassarikhan786 likes this.
  2. DeadP1xels
    30 Nov 2009
    How much it going to cost to rent that thing out? does it come fully furnished or can i put my own sofa in there :D?
  3. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Well... The welding already failed:wallbash: So now i am halfway done with making new ones of 6 mm steel :rock:
    I think I can find a little corner for you to reside in:D No furnitures though, so bring your own:brrr:
  4. bulldogjeff
    2 Mar 2010
    Have a look at this.Durafix rods http://www.durafix.co.uk/
    I've had a play with them and they're pretty good.
    Oh and the brackets looked good, how badly did it go wrong?
  5. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    My guess would be that the "legs" evaporated! :worried:
  6. bulldogjeff
    2 Mar 2010
    i think that could be classed as bad.
  7. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Damn, should have known about this stuff 3 days ago:p Oh well, Steel is stronger anyway :rock:
    Spot on :lol:
  8. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Yay another Pope build! Missed the start but I'm here to stay now :D
  9. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Hehe, settle in, its gonna be a long and bumpy ride:D (get moving with 22 in the meanwhile;) )
  10. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Well, as the previous alu stands failed duo to not being "weldable" I decided to make some of 6 mm steel! This will provide better rigity, and I made them look better this time!
    A picture of the failed alu welds.
    Used the old stands as reference, and then bolted them together.
    These are the new ones, with the old alu one to the left.
    And again, new versus old.
    I am going to make the support rods tomorrow, and hopefully get it welded too! Lets hope second time is the charm lol.
  11. bulldogjeff
    2 Mar 2010
    Aluminium's easier to work with,but at least you know thats going to stay in one piece when it gets welded.
  12. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Cool, I subbed.
    I know it's a bit late now, since you already made replacement pump holders in steel, but couldn't you just have bolted them to the support bars, instead of welding? If you had placed the brackets correctly, you could even have utilized the threads in the radiator for securing everything.
  13. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Yeah, these steel brackets are sturdy as he!! :D
    The profiles was only 4 mm thick, so it would have been some week stuff, and not look good:/
  14. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    I heard you could only use TIG welding on aluminium unlike steel which uses MIG, or you could use brazing to create joints.
  15. Angel OD
    16 Sep 2007
    pOPe <- Yay, I was right! :lol: Unfortunately for you though! :)
    Nitrixflare <- Yes and no. The posibility of welding aluminum with MIG is also present. But you need a MIG welder that can feed an aluminum wire... Dunno about Co2 vs. Argon on MIG though! :)
  16. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    I like that case, will be watching with much interest :D
  17. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    And welding and filling done! After my .cad exam I picked this up from the workshop. A buddy had welded it in the meantime, and I went straight home and put the pumps on:D
    How it looks in its full scale, mounted on the radiator. Did I mention that it is sturdy as hell!?
    A close up of the milling. I also countersunk the screw holes for good looks:)
    Had to fill about 2 mm off the Bitspower crystal link to get it to fit, but now its like a glove!
    Cant decide what color I am going to paint it, but I think that white might be the choice!
    Hope you like the end result here:) Now its on to the top!
  18. bulldogjeff
    2 Mar 2010
    Thats some tidy welding .
    The one thing that bothers me with this set up, is how it's going to affect cooling performance with that much of the rad covered.
    It looks ok, it's probably just me being over cautious about blocking air flow off.
  19. Nutman
    21 Oct 2008
    Love it, p0Pe ;)
  20. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    I honestly dont think it will matter:)
    1; I have 3 360 mm radiators, so there should be plenty of cooling potential.
    2; Its really not that much that gets covered:D
    Thank you Mads;)
