Been a bit of a change to my rads choices,seeing as the AMS is TOO damn big,i am using XSPC RX 480s instead....
Some of the loop which came today.. 24v capable D5's Bitspower Res..why would you buy anything else?? Some of the fittings.. Dual 24v pump controller 2 480 XSPC rads... Special mention and thanks to Coolmiester at XSPC for 1 of the 480 rads and to Steve at Specialtech for getting in AMS rads in especially for me that i cant use...i know he spent a good few hours trying to source these for me. Still waiting for one more 480 rad and 2 Koolance D5 tops then i can get going on the loop. Ordered more 10mm Copper pipe today so i can get on with the pipework.
I have 180 bends on the loop which counts out using the double o-ring fitting (phobya/BP sli fitting),these are push fit with a lock ring,much more secure and reliable. Looks,in this instance,are secondary to performance.
i'd not come across the "single use Koolance Pipe fittings" before that you are using. +rep for bringing them to my attention!
Thanks. You can get them in the UK here. http://specialtech.co.uk/spshop/cus...or-38-10mm-OD-Tubing--NZL-CU10-pid-15374.html
I don' think they're ugly. They're.... classic. Also, it's slightly refreshing to see somebody NOT using Bitspower, EK or Feser fittings.
Spider at SpecialTech sent me his old Ram....for free no less! Many thanks to the miserable old git,i really appreciate it.
Moar pipe bending today,got the spacers i forgot to order! ST got my stuff out fast as usual. Taking shape now...
Nice start man! I really like that you will use metal pipes that will make it a very unique thing! I prefer the 90° bends over the 45° bends btw, 90° just looks better
Delivery turned up with goodies... This PSU screams Quality,very nice choice i think...plus the cables look easy to braid with no double wires! Result! a free fan you say? some enermax 'stadium light' job... Specs for the unit.. Dominator GT's and a Force GT SSD.. I wont be using the airflow fans tho.. Looks mint dont it. So....time for some work!
I am just sleeving one of those for a custumer https://www.facebook.com/media/set/?set=a.293863110700656.74138.172900899463545&type=3
