Hi guys Mainly for gaming,do i go.... AMD 9..5900x.....or Intel i9..11900k...or what do you guys recommend, my last pc was i9 9900k....thanks
Whichever is actually in stock? Both will work for gaming, both are very powerful cpus, but what are you planning on pairing with it (Screen res, GPU, etc)?
Thanks matey, im thinking Rtx 3070 32gb memory 3600mhz No room for high end monitor so will have to use my 55" smart tv,thank you
either would work tbh, get whichever has the higher fps in the games you want to play more. when paired with a 3070 I don't think you will have any bottlenecks any time soon anyway
My son has my old rig pete,im thinking of building a newu one,not sure which way to go...Ryzen or intel buddy
Have you considered the 11700KF? It is almost half the price of the 11900K and the difference is negligible. https://www.techpowerup.com/review/intel-core-i7-11700kf/20.html
When you are born in Scotland and spend your childhood years in Liverpool while Dalglish is in charge...
