Guide 15 button Hotlink Panel (1meg of images)
Discussion in 'Modding' started by bigal, 20 Oct 2004.
  1. bigal
    bigal Fetch n Execute
    8 Oct 2004
    ok, i have had this mod for about a year, when it suddenly occured to me that, since I stumbled upon it by acident, many people may not know the shear simplicity involved in it. Basically, you install & run this software which interfaces with winamp, windows and more. You then build this very easy interface using the SERIAL port (nice change from all the parrallel mods) now, you can either use 4 buttons and no diodes or 15 buttons and 28 diodes, it also allows for a led, which is pc controlled (although something went a bit weird with me, and i have two leds which alternate....)
    Anyway, first thing to do is go download the software here:
    Bottom of this page
    Have a read through there to. Look at some picture examples for inspiration!
    I will say now, the software is damn stable, i have never had any issues and it is not resorce taking.
    This quick guide (i hate typing) is on the 15 button version.
    picture 1
    Things you need:
    1x serial port plug and housing (9 pin D shell plug)
    1x 680 - 1k resistor
    1x 9 core wire - any length
    15x momentary push buttons
    28x diodes, 1n4148, kd-521, kd-522 ALL MUST BE THE SAME
    1x box or similar to shove it all in
    1x soldering iron + computer
    2x houres of your precious time
    patience and eyesight, if you put one diode in backwards, it all goes haywire. (not damaging to pc, just when you press a button it does lots of other stuff too.)
    FIRST
    Solder the serial plug onto the wire, making notes of all wires, disregard the wires going to pins 7,3 and 2.
    SECOND
    Mount the led, all buttons and wire into a housing, well wire going into the housing, you know what i mean :rolleyes:
    THIRD
    SOlder one side of every swith together and connect to pin 4 of serial wire
    attach the following number of diodes, rings away from switch, to the following swithches ( the other terminal, not the one you have just joined together,
    3-2
    5-2
    6-2
    7-3
    9-2
    10-2
    11-3
    12-2
    13-3
    14-3
    15-4
    first digit is the switch number (inportant to make up a number for each switch) second number is number of diodes.
    FOURTH
    Pin one of the serial poet goes to ONE diode (any) of the following swithches:
    3,5,7,9,11,13,15 and also swith one (no diode)
    Pin six of the serial poet goes to ONE diode (any) of the following swithches:
    2,3,6,7,10,11,14,15 and also switch two (no diode)
    Pin eight of the serial poet goes to ONE diode (any) of the following swithches:
    4 (no diode) ,5,6,7,12,13,14,15
    Pin nine of the serial port goes to ONE diode (any) of the following swithches:
    8 (no diode) ,9,10,11,12,13,14,15
    Fore poeople who just are screaming for a schematic, the program provides one, but here is the same one now:
    Picture 2
    Connect the cathode (negative) of the LED to pin 5 and the anode (positive) to pin 4 via the resistor.
    Now stick it all together, connect it to your mobo and start assigning buttons!
    I TAKE NO RESPONSABILITY FOR YOU SCREWING YOU MOBO UP WITH THIS AT ALL. UNLESS YOU REALLY SCREW UP THE WORST I CAN SEE HAPPENING IS A DIODE IN BACKWARDS, WHICH RESULTS IN A BUTTON ACING AS ANOTHER. have fun! :hip: :D
    Closeup of buttons 1
    ratsnest of wiring 1
    Wiring 2
    :clap: good luck!
  2. shroom
    shroom What's a Dremel?
    6 Aug 2003
    I applaud your valiant usage of spare time. Very well done indeed.
    If I had done it, I would've gone for smaller switches and a more streamlined look. But, then again, if you go completely blind youll still be able to work the switches on yours :thumb:
  3. ChegsJAR
    ChegsJAR What's a Dremel?
    7 Sep 2003
    looks really good
    guide abit confusing for me though :wallbash:
  4. Starfighter
    Starfighter What's a Dremel?
    4 Apr 2004
  5. Meeper
    Meeper What's a Dremel?
    14 Oct 2004
    Can you completely control Winamp, including choosing play lists? If so, I can see my PSone screen and some buttons coming to good use...
  6. Skylined
    Skylined Minimodder
    3 May 2003
    I did that some time ago, and I really sugest making your own IR receiver circuit, you'll love to have a remote control instead of a bunch of buttons. ;)
  7. Firehed
    15 Feb 2004
    You're awesome! I love you... I needed something just like this. :thumb:
    Do you think Cat5 cable would be thick enough to interface the device to the serial port? Sure looks better than a half dozen odd wires flying about to a plug... (although sleeving could work too I suppose) I'm more concerned with the LED than anything else. Also, on that site, it says to wire the LED to 4 and 7 or 5 and 7, you say to ignore pin7 and wire it to 4 and 5
    /me needs to find a ton of switches and wire now
  8. bigal
    8 Oct 2004
    Meeper: Yes, you can add create new playlists and add files and stuff using the commands available. :D
    Firehed: THanks and yes, Cat 5 cable is fine as it has 8 cores, the led is optional and i did something wrong in mine with that, as i said, but i have it as it is in the daigram, and it works fine. :idea:
    Starfighter: nice n neat, but 5 buttons? is it 4 button setup with last button not functional or is it 15 button setup with only 5 buttons? :eeek:
    Skylined: I made an IR reciever system but found it not as good, i have 5 meter cable on this which does me fine, IR is a pain when it is outta range... :wallbash:
  9. Starfighter
    4 Apr 2004
    It's actually a 4 button set up, purely because I couldn't find any diodes knocking about. Let's call the spare button a magic button :)
    It's not such a worry though, since I only ever use the "skip" button on it anyway.
    It's mainly a convinience so I can change the track on the computer if I've left it for a while, without having to type in a password / wait for the monitor to fire up..
  10. Firehed
    15 Feb 2004
    You wouldn't happen to know of a place that sells a whole load of pushbutton switches cheap, would you? I'd spend a small fortune locally :rolleyes:
  11. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    firehed, I believe they are called "junkyards" or if your more lucky Recycle centers, obsolete computer places etc. I felt cheap but I got a lot of the components for my case from flea markets, old scanners etc
  12. bigal
    8 Oct 2004
    ebay = good for that soft of thing... :D
  13. Firehed
    15 Feb 2004
    I suppose I forgot to mention they should all be the same...
    /me ponders 15 vandal resistants, a relay-based luxeon, and the $200++ bill
    Actually if you're good at binary, you could make the 15-button version of the software work with four buttons.
    Of course what I'd really like to do is make something the way a keyboard is done, with copper traces on a thin sheet of plastic like an overhead transparency. Too bad I don't have a copper-toner cartridge.
    ebay isn't really my thing but I'll see whats there anyways, thanks for the tip
  14. Black
    Black What's a Dremel?
    5 Apr 2004
    its working only for winamp ? or i can use it for everthying in windows ?
  15. ARM
    ARM Minimodder
    15 Sep 2004
    Black,
    You can use it for any programs in Windows, go to the 'WinAmp' tab in the COM Port properties and you can assign functions to the buttons (to start programs, act as a key press, shutdown, reset etc).
    Rgds,
    ARM
  16. bigal
    8 Oct 2004
    softwares the same reguardless... Just an option to select which one you have built.. :)
  17. alter_ego
    alter_ego What's a Dremel?
    26 Jun 2004
    great guide, cant wait to use it for my htpc, does it work on a sort binary basis, when using 15 buttons
  18. Firehed
    15 Feb 2004
    More or less. 11 of the 15 buttons are really just combinations of two. Count to 15 on your hand in binary and you'll find it remarkably close to the schematic. Actually identcal, minus the diodes and whatnot. But you can't push more than one at once in 15-button mode to have it act as (2^15-1) combinations.
    What I was saying is that if you wire it up with only four buttons (if you download the program there's a schematic for it), you could push combinations of those to have it work with the 15-button setup.
  19. Springs
    Springs Boing boing
    29 Aug 2004
    i have been thinking about making one of these since i saw this thread..... i only want to use 8 buttons... is it possible just to not add the last few buttons to the circuit?
    one other thing.... where did you get your components from? a local electronics store or a known electronics shop?
  20. bigal
    8 Oct 2004
    yeah you can use upto as many buttons as you like.. just "remove" from then on on the schematic. I got my stuff from maplin... expansive i know.. :duh: One of my first projects about a year ago now.. :)
