Graphics 2060 Super vs 2070? Same price, big difference?
Discussion in 'Hardware' started by 13thHallow, 2 Feb 2020.
  1. 13thHallow
    13thHallow What's a Dremel?
    25 Jan 2020
    As per my other thread, I'm upgrading from a GTX 970, and having looked into the relatively messy release of the last few AMD cards, I think I'm sticking to the green team.
    I want to buy new, and I have a top budget of £350. This is for 1080p 60 Hz at the moment, and I'm thinking that 1440p ( 60Hz) could be on the cards some time this year....
    I know the 2070 is technically not made any more, and there's a fair few more 2060 Supers to choose from, but is there a great difference in the two models?
    Basically looking around it seems that I could get a ' Cheap' stock 2070 or a 'better' 2060 Super OC?
    Am I right?
    Any input would be great!
  2. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    Pretty much identical performance.
    £328 for a Palit RTX 2060 Super compared to around £354 for 2070's.
    I would go for the 2060 Super as it has pretty much identical performance for a few less pounds.
  3. The_Crapman
    5 Dec 2011
    2070 will just edge it, with a few more cuda, tensor and rt cores. 2060super makes up for it with slightly higher clocks, which can be overriden with a minor overclock.
