Graphics 22/23 GPU Thread - RTX4000 AND RX7000 Series
Discussion in 'Hardware' started by The_Crapman, 19 Sep 2022.
  1. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Now, we wait for review NDAs to expire...
  2. sandys
    sandys Multimodder
    26 Mar 2006
    Really interested in how well MCM works here, essentially Crossfire on package, hopefully compatibility is no issue, nice price, sounds like it's going to come in under a 4090 in performance.
  3. Anfield
    Anfield Multimodder
    15 Jan 2010
    I would assume preventing the massive inherent problems of crossfire / sli is the reason that the main part of the GPU is still very much monolithic with only some specific parts being moved to chiplets.
    sandys likes this.
  4. sandys
    sandys Multimodder
    26 Mar 2006
    Ah I see, not had a chance to sit and watch it yet but it seems it is GPU die and cache dies, so likely no multigpu issues as it is one GPU, I thought the MCM approach was going to be multiple GPU die.
    Should they do a dual GCD then it would be Crossfire like, I wonder if this approach will ever be taken.
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    Yeah its basically one GPU die + multiple cache and memory controller dies.
  6. The_Crapman
    5 Dec 2011
    I thought it would be more zen like with multiple GPU dies per chip, but that's probably the next step as they iron out infinity cache and fabric problems for the highly parallel GPU architecture.
  7. David
    7 Apr 2009
    I see the reference models have no venting in the IO plate. So they dump ALL of their heat inside the chassis?! :eyebrow:
    I'm assuming/hoping these are just render oopsies.
    [edit] nope, no oopsies - deffo a solid rear plate.
  8. Omnislip
    Omnislip Minimodder
    31 May 2011
    How much energy _really_ escapes via the IO plate? It seems better to allow some than none, but I have been skeptical about how much of a difference it makes. If it were a large difference, surely every card's fin layout would be lengthwise rather than widthwise, as they'd score better temps and more units sold?
  9. wyx087
    15 Aug 2007
    Personally, I'm a fan (har har) of lengthwise fin layout. It makes possible for better passive cooling using a fan at the other end, it also blows a lot of hot air directly out of rear IO, finally it doesn't heat up M.2 drives by blowing heated air over it, yet there will still be some air from edge of GPU fans over the M.2 drives.
    nVidia FE method also works well. Clear paths for all the air to flow.
    There's mention that the 7900 ref cards have temperature probes near one of intake fan. Suggesting it will read out card's ambient temperature. So the concern that all the heat will be trapped in a hot-box has been considered by AMD......... one would hope.
  10. Vault-Tec
    30 Aug 2015
    This is not AMD's big card. Not yet.
  11. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Bad news for wallets - Both Scan & Overclockers have 4090 AIB cards in stock right now!
    Worse news - £1825-2180
  12. The_Crapman
    5 Dec 2011
    Yeh prices are a piss take. My brother wanted me to do him a new build and wanted a 4080, until he found out they're £1300+
  13. Vault-Tec
    30 Aug 2015
    The AMDs should cost half that. I say should, because scalp+gouge=BS, but yeah....
    IanW likes this.
  14. RedFlames
    23 Apr 2009
    i think $999 equates to £1100 once vat and other bollockry is factored in...
    So I'd expect the AMD pleb spec model to be that and partner cards to be £1200+
  15. Vault-Tec
    30 Aug 2015
    Yes. At least that.
    However, that is still cheaper than the 4080, and it should be a good chunk faster.
  16. Vault-Tec
    30 Aug 2015
    3DMARK just leaked. They are 50% faster than a 3080, whilst being 100% more expensive.
  17. RedFlames
    23 Apr 2009
  18. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Makes me sad to see EVGA are gone from the game, that 4090 is a thing of beauty.
  19. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Jay got a working one.
  20. Mr_Mistoffelees
    26 Aug 2014
    If you put a GPU like that, in a case without adequate airflow, you're an idiot.
    wyx087 likes this.
