Graphics 22/23 GPU Thread - RTX4000 AND RX7000 Series
Discussion in 'Hardware' started by The_Crapman, 19 Sep 2022.
  1. David
    7 Apr 2009
    Arboreal likes this.
  2. Arboreal
    21 Jan 2011
    What price do we think the 4060LP is going to come in at?
  3. David
    7 Apr 2009
    £329 to £349 maybe?
    I wouldn't be surprised to see some kind of premium for a sff card.
  4. Arboreal
    21 Jan 2011
    Not cheap, but a potentially economical replacement for an A2000, which still seems to list at £240 upwards
  5. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    Could potentially be a new lease on life for refurb'ed office PCs. That's always been a great way to get into PC gaming, but you do have to be careful about proprietary parts - particularly power supplies. Even machines that use proprietary coolers, motherboards, cases, etc are better off with a second lease of life, rather than being in landfill, but if it's a non-standard power supply which doesn't use ATX connectors you're pretty screwed.
    EDIT: Still pricey for what it is though.
  6. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  7. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  8. Goatee
    Goatee Multimodder
    19 Apr 2015
    Im doing a ITX build for a friends 40th in an old FORMD T1 V1 case I have that needing a new home.
    Im using a number of used parts to keep to the grand budget and have almost everything except the GPU (and the ram I have a wanted post for). My remaining budget will be ~£550 for the GPU and need to finish it before October.
    Im tempted to pick up a 4070 founders to sit in the 3 slot space but looking for any additional feedback / thoughts on the current GPU market.
    IanW, David, adidan and 1 other person like this.
  9. David
    7 Apr 2009
    Thems some chunky feet you got there.
    Goatee likes this.
  10. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I guess they keep the dust bunnies out.
    Goatee likes this.
  11. The_Crapman
    5 Dec 2011
    for a smidge more you could get a 6950XT. whether is would fit or not is another question.
    Goatee likes this.
  12. The_Crapman
    5 Dec 2011
  13. Goatee
    Goatee Multimodder
    19 Apr 2015
    It originally had a floor mounted rad, so needed the clearance for good air flow. I havent changed them, as I quite like the look now, over the feet the case came with.
    Its only running a SF450w power supply. The CPU (12700H) has a max turbo of 115w, but normal usage around 50W, so the the 6950xt takes it close with ~300W vs the 3070 ~200W....
  14. Vault-Tec
    30 Aug 2015
    The MBA card may fit. I doubt that would.
  15. Goatee
    Goatee Multimodder
    19 Apr 2015
    Max length is 312mm, so at 340 that wouldnt fit even if I wasnt worried about power usage. Good point
  16. Vault-Tec
    30 Aug 2015
    Yeah you lose 10% perf on the MBA, but they are tiiiiiny compared to aftermarket ones.
  17. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    NDA just lifted on 7700XT & 7800XT. Reviews are everywhere.
    adidan likes this.
  18. RedFlames
    23 Apr 2009
    So it's a slightly more power efficient 6800XT
    performs worse than it in some scenarios
    and the 6800XT has been available for around the same price for quite a while.
    tbh this entire gen, from both sides, can just **** off.
    yuusou likes this.
  19. The_Crapman
    5 Dec 2011
    Tbf the 6800xt was a cut down price and as they've run out of stock you get about the same performance for that same price with added efficiency. They could have priced the 7800xt the same as a 4070, so they're at least breaking away from the Nvidia pricing model for the first time in a while.
  20. Vault-Tec
    30 Aug 2015
    The 6800XT is nearly 3 years old.
    The 7700XT can be had from Scan for £429 for the XFX Qick. The 7800XT can be had for £479. Again from Scan. Apparently OCUK will drop their prices soon.
    The 6800XT RRP almost three years ago was £649. However, most of those who got them then would have paid a grand or more.
    And people still complain /roll eyes.
    I wouldn't say it is the best release ever, but god it is far from the worst. Dare I say it I think they are very reasonable.
