Linux 3 monitor support on ubuntu on linux mint?
Discussion in 'Tech Support' started by isaac12345, 4 Feb 2014.
  1. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Hi all,
    I am planning to buy a laptop with a vga and hdmi port. I would like to hence use three displays, 2 external and the one on the laptop. Is it possible to do so on the latest version of linux mint or ubuntu?
    THanks!
    docodine likes this.
  2. theshadow2001
    3 May 2012
    I've done dual monitors on ubuntu. I'd say triple monitor would be OK too, although I have no direct experience.
  3. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    just a warning i have a laptop with both d-sub and hdmi but can only display on 2 monitors at any one time
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    depends on the laptop. just because it has 2 video outs doesn't mean it necessarily supports output to 2 displays
    you may need a multi monitor adapter from evga or matrox (among others). they're not fast though, you'll basically only be able to display text on them (i.e. no games or video)
  5. jinq-sea
    15 Oct 2012
    You'll most likely find that using one of the ports for an external display will mean the inbuilt ceases to function - as docodine says, you'll need a USB VGA adapter or the like. Or you could just run the laptop shut and connect two big external displays?
