News 360 & PS3 have equal power?
Discussion in 'Article Discussion' started by Garside, 1 Nov 2006.
  1. Garside
    Garside What's a Dremel?
    27 Jan 2006
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    This has been known for a while, I think other developers have commented on it. Each console might be better in particular areas, but when you add it all up, they're about equal. :)
  3. DougEdey
    5 Jul 2005
    The only thing that PS3 had going for it really was the exclusive titles, but with MGS4 rumoured to be hitting 360 and 360 having a fair few big hitters under its belt which will never leave it seems like Sony are getting in trouble.
  4. Guest-16
    Guest-16 Guest
    It's entirely true. The PS3 has 256meg XDR rambus based memory and 256meg GDDR3. Despite the fact that the RSX can talk to the GDDR3 as well as XDR, being different speeds and memory sets means that using them both for texture memory is going to be exceptionally difficult to code for and it will fill the inter-buses with graphics IO rather than game IO. Even though Sony has made it easier to code for in C++ etc
    I think we'll see a more massive extrapolation of the PS3s power in the next 2-5 years like Square has done with final fantasy, or the guys who made resident evils did with the cube. Moreso than the 360 which is "easier" despite the fact it's still a multicore/unified shader that's "new". It's still got pc-esq components.
    I think this guy is right on the money with his opinions.
  5. Houck
    Houck What's a Dremel?
    11 Jul 2006
    Althrough the Xbox 360 games are way better :D
  6. Veles
    Veles DUR HUR
    18 Nov 2005
    Yeah thats what I've heard, although the PS3 may have more processing power that the 360, it's meant to be a right bitch to program for.
    The xbox 360 on the other hand is meant to be very easy to work with, Gears of War was originally meant to be an xbox title and it took them only a month or two to completely convert (not port) the game as it stood for the 360.
  7. riggs
    riggs ^_^
    22 Jul 2002
    So if they're generally almost equal in power, it's up to the consumer to decide whether or not it's worth paying the extra cash for the PS3 exclusive titles (and risking buying into the [not yet standard] Blu-Ray phenomenon).
    I will end up getting one at some point (2nd hand, no doubt), for the exclusive titles I'll inevitably want to play.
    imo though, they seriously need to stop all this BS hype - ok, so the vast majority of the public are idiots, and will believe anything you tell them, but surely they're gonna be pretty p**sed when they find out their hard-earned cash has essentially bought them a 360 equivelent, with a BR drive...even moreso if BR ends up redundant.
    The PS3 will still sell in massive numbers - but that's not surprising when you consider the crap they feed Joe Public.
  8. TheSaladMan
    TheSaladMan What's a Dremel?
    15 Sep 2006
    I thought this had been known for quite a while now, hell the PS3 is such a bitch to program for that the Assassins Creed devs have come out and said that the AI is gonna be alot better on the 360.
  9. Chuff_72
    Chuff_72 What's a Dremel?
    18 Oct 2006
    Yeah, this news has been known a while, read a pretty damning report on the PS3 version of Oblivion on IGN, you should check it out, I read it with a kind of half grimace, half smirk (must have looked pretty weird!). The interview starts with a standard "We've been porting this game for ages already..." then the IGN guy starts asking the standard q's;
    What new content is there?
    A new 20hr quest.
    Will this be available on the x360?
    Yes
    How have you improved the graphics?
    They are the same as the 360, with some new shaders and the middle distance is now smoother.
    How have you used the hard drive?
    The same as the 360.
    Will you be able to download content?
    Not at the moment as we don't know how this will work!
    Are you using the tilt function?
    No.
    Will the PSP have any conectivity?
    No, sorry.
    This piece of news lead me to finally purchase a 360 2 weeks ago.
  10. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    As far as I know the designs for the major hardware parts were finalized at about the same time were they not ? I think we can assume that both would try and get away with as much power/heat as possible and using the same generation of technology, that isn't likely to differ too much, hideously expensive, almost impossible to leverage anywhere near the theoretical power of cell processors (so say, for example Epic megagames I believe) aside :hehe:
  11. Guest-16
    Guest-16 Guest
    The fact is also, because it costs more to code for it, the dev teams will then charge more for the games for longer. The RSX chip is based on 7xxx technology too, so whilst the Cells are fantastically powerful, unless they do graphics as well (also a bitch to code for RSX and Cells to do the same thing) it can't be much/at all better graphically than the 360.
  12. Veles
    Veles DUR HUR
    18 Nov 2005
    What it all really comes down to in the end is the quantity of high quality games, Sony are in a bit of trouble here though because I've heard they havn't got that much support from developers, who'd much rather program for a easier machine, like the 360.
    All this stuff about "ooo look at these fancy cell processors" doesn't mean anything if you've not got decent games to use them, the only use videos like riggs linked to is for developers, and I really doubt they're gonna be swayed by some buzzword bull****.
  13. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    people will buy the ps3 anyway.
    "it it is expensive it is good because quality is not cheap"
    but this is funny anyway.
  14. Guest-16
    Guest-16 Guest
    Sony still have a lot of loyal Japanese developers who are willing to throw many man hours into games, that's their advantage.
  15. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    I'm not suprised he's glad E3 is over. Almost every developer is glad that's done with. Especially him, since Too Human got slammed last E3 because it was choppy and hard to play. He said the final product will be NOTHING like the E3 demo. Too Human is -THE- game I am looking forward to for 360, though.
  16. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    Its not how big your bus is, its how you use it. Or so my virtual girlfriend says.
    In all seriousness though did anyone actually think the ps3 would be so many times more powerful than the 360? The ps3 after all was not all that powerful. Just when you code and develop specifically for it you can utilize the platform specific advantages.
  17. Veles
    Veles DUR HUR
    18 Nov 2005
    True, but alot of big name developers have splintered off from thier old companies and have signed exclusive deals with MS.
    They can't really conquor europe and america without some big name western developers signing exclusives (like Rockstar, GTA games are always a big pull for customers), after all, the majority westerners wouldn't buy a JRPG unless it has Squaresoft on it, and many other japanese games never see the light of day over here.
    But like many people have said, it will sell out just because it's called the PS3.
  18. Aankhen
    Aankhen What's a Dremel?
    15 Oct 2005
    [citation needed]
    Yes, I've been looking at too many Wikipedia articles of late. :p
Tags: Add Tags
