3DMark2001 score!
Discussion in 'Hardware' started by Dremel_Freak, 9 Sep 2001.
  1. Dremel_Freak
    Dremel_Freak What's a Dremel?
    18 Mar 2001
    Here's my latest score after a fresh install of Win98SE which is supposed to be the fastest platform for benchmarks:
    Systems specs are as follows:
    AMD AYHJA 1.4 @ 1.6GHz [10 x 160, 1.90 volts].
    POWERCOOLER PCH137 WITH 70mm TURBOFAN.
    ARTIC SILVER II THERMAL COMPOUND.
    NON-CONDUCTIVE COOL SHIM.
    EPOX EP-8K7A+ MOBO.
    256Mb CRUCIAL DDR [2 x 128Mb]
    THERMALTAKE RAMSINKS.
    GAINWARD POWERPACK GF3 @ 210/512 [Won't go higher]
    LIAN LI PC2 ALU CASE
    D-LINK 10/100 DFE-530TX NETWORK ADAPTER.
    YADA, YADA ..........
    For an air-cooled system I'm pleased with this score but I'm after an ASUS V8200 as they seem to clock much higher so that should push the score up to 7k or more - so I'm selling the Gainward! :cool:
    Anyone got a similar setup using the ASUS V8200 Deluxe lemme knoe what your benches are and if it's worth changing over.
  2. Phil
    Phil What's a Dremel?
    19 Jul 2001
    I take it you've seen this :
    That was with the Asus naturally...
    details here
  3. Dremel_Freak
    18 Mar 2001
    Yeah - the ASUS and an Athlon CPU running at over 1800MHz, which must be vapochilled to reach that! I'm only at 1600MHz right now, air-cooled.
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    heh .... benchmarking is pointless in my opinion ... if you can play the games you want at a decent frame rate while it looks good it doesn't matter what score you get...
  5. Dremel_Freak
    18 Mar 2001
    You're just saying that 'cause your score sux :D
    Only pulling yer Limp Bizkit - don't go in a huff dood!
  6. Dremel_Freak
    18 Mar 2001
    Improved score with new Detonator 4 drivers:
    Slight improvement there I think :D
    NVIDIA have done an awesome job with these new drivers, I saw the frame-rate on the infamous "Nature" scene hit over 40fps, previously they sat at around 21fps - that's double the performance from the same hardware. ;)
  7. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    Nice score :)
    You should be proud, I would be.
    Remind the old man what this looks like?
    Doesn't ring a bell.
    Piccy Please :)
  8. Dremel_Freak
    18 Mar 2001
    Review up shortly of at the 'Zone of the Powercooler PCH137.
  9. [GiB] Spawny
    2 May 2001
    I take it must cut the mustard then?
    Go on post a pic!!!!
    You no you want to?
  10. Dremel_Freak
    18 Mar 2001
    Patience my young apprentice! Yes, it does cut the mustard at these speeds.
  11. Dremel_Freak
    18 Mar 2001
  12. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    now now children!
    oi u pimp masteh! seen the spam forum? :)
  13. Dremel_Freak
    18 Mar 2001
    Nope - what's that about? He asked for the skinny, I gave it to him - what am I to do?
  14. Koolvin
    12 Mar 2001
    calm down bro! i was kidding thats why i put a smile there
    jeez!!!!!! :)
  15. Dremel_Freak
    18 Mar 2001
    Thought u was having a go! No problem dood :D It's a nice cooler though.
  16. Koolvin
    12 Mar 2001
    BTW the dt4 give better results in XP (so i am told)
    and the 21's are better for win2k but u use win98?
    lemme know with XP when u get it :D ;)
  17. Dremel_Freak
    18 Mar 2001
    Yeah, I'm gonna run it on Win2k and see what happens. XP should be coming my way soon hopefully. 8008 ain't bad for clunky old Win98SE eh!
  18. Koolvin
    12 Mar 2001
    8008 aint bad at all! but just remmeber if u are doing this for competeing rather than playing games then everyone else's score goes up at the same rate whhich means you are really at the same level ;)
    unless you play games!!! then your a winner!!!!! congrats to nvidia to sortin thier drivers out (bet they had em ages ago)
  19. Dremel_Freak
    18 Mar 2001
    Isn't playing games competing too? The fact that I've switched graphics cards means that my scores should be higher than before, not just because of the Det 4's. So you're incorrect saying that I've just stayed at the same level, I have in fact gone up a level at least due to the much higher overclock of the ASUS V8200 GF3 - so there :D
  20. Koolvin
    12 Mar 2001
    you never said you *had* a Asus!!! damm joooo!!! :)
    well gaming is competing but its also recreation and enjoyment...
    i wanna be able to play at 1600*1200 so improved drivers will help me do this which is performance (why I brought the card) not compotition!
    i know you you.....
    your a speed freak!!!!!! hehehe you wanna have the fastest baddest and menaest init?
    ...don't deny it mr PC*Power*zone man you!
    PS when i say i brought the card - I aint got a gf3 i was speakin hypothetically!
