Hi, I just got a new rig. It's a 2500k with the 560 Ti Twin Frozr II OC. I just wanted to make sure its not running too hot, here are some numbers. Ambient Temp : 26C 560 Ti : IDLE(AERO) 34C, LOAD(Dirt 1 @ full settings) 72C 2500K : Idles at 40C Is everything ok? Thanks!
Mine idles at 29, maxes around 55, is over clocked per my sig. Check you case airflow and install MSI Afterburner to create a custom fan profile. How long will it last you? How should we know?
What case do you have? My GTX 480 used to run at 95C under load, so you are well within thermal limits.
I think he means in game grunt terms! At standard HD it should last a good time as the 560Ti has plenty of horse power. Also those temps could be better. What case do you have and what CPU cooler is installed?
I have a CoolerMaster Hyper 212+ for my CPU, everything is sitting inside an HAF 912 Advanced. There's no side fan, one 200mm on top, and one in the front. A small one at the back as well. Also, I maxed out GRID on it for a couple of minutes, and found that it never goes above a 65C. And @Cleggmeister, could you tell me what ambient temperature you're running it at. I'm sure that makes a difference. I asked how long it's going to last me because, I've owned an 8800 Ultra which burnt out in less than a year, I don't want that to happen again!
That's a good 10C differential right? My car idles at 7C above ambient, which seems cool enough. Looks good!
Depending on room temp my 560Ti twin frozr idles at anywhere between 28c and 33c, underload I've yet to see it break 62c with afterburner keeping the fan at around 52%.
Well then I think I'm safe. I'll see if need to speed up the fans manually. Doesn't the card to that itself? PC gaming forever!
YMMV based on a few factors too - temp sensors aren't really that accurate without being calibrated, not to mention your case can radically affect how the card is cooled. I wouldn't worry.
