Graphics 670 on PCIE2
Discussion in 'Hardware' started by boltonuk007, 28 Nov 2012.
  1. boltonuk007
    boltonuk007 What's a Dremel?
    29 Sep 2011
    Hi guys,
    As you can see from my sig Iam running a GEN3 board with a 2500K. My question is if I bought a 670 and didn't upgrade to IB thus not enabling PCIE3, would I be losing out? Would the card saturate my bus or would I be looking at something much more powerful than a 670 for that to happen?
    Thanks.
  2. Cei
    Cei pew pew pew
    22 Mar 2008
    You'd be needing a 690 to be even approaching PCIe 2.0 saturation, so don't worry about it :)
  3. boltonuk007
    29 Sep 2011
    Just as I thought/hoped!
    Ta
  4. Silent_Raider
    Silent_Raider What's a Dremel?
    20 Aug 2010
  5. boltonuk007
    29 Sep 2011
    Excellent, thanks for that, always nice to have some data to feel extra reassured!
  6. rollo
    rollo Modder
    16 May 2008
    Duel 690s bearly hit pci e 16 2 bandwidth
  7. boltonuk007
    29 Sep 2011
    Then it poses the question as to why PCIE3 has been issued now then, would a SATAIII card with multiple SSDs test it?
  8. Silent_Raider
    20 Aug 2010
    1. To add a feature to sell Z77 motherboards.
    2. To prepare for future cards.
    3. For PCI-Express SSD Cards. Current Gen are PCI Express 2.0, but they can saturate the PCI Express 2.0 lanes.
  9. rollo
    rollo Modder
    16 May 2008
    That's pretty much why its been done
    People running raid cards with pcie and 10+ssds for like 2-3gb read/ write anandtech ran a few tests. 10 Samsung 830s 256gb hit around 3gb/sec read write.
  10. boltonuk007
    29 Sep 2011
    Well SSDs were the only thing I could think of, for those it makes sense
  11. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Because Intel and it's mobo partners needed to give people a reason to upgrade to ivy from sandy and the z77 chipset other than 'it's a tiny bit faster while using a tiny bit less juice' and trying to bypass the fact it doesn't overclock quite so well.
  12. rici1241
    rici1241 Minimodder
    4 Jan 2011
    Another reason was to reduce the number of lanes for the same performance.
    Instead of having to use an 8x slot, add-in cards can achieve the same bandwidth with a 4x slot.
    This reduces the number of traces required on the PCB, which in turn creates more PCB space, while saving money.
    Very little can max out 16x PCI-E 2.0, but when it is surpassed, manufactures don't want to be waiting for another revision. Modern SSDs are prime examples of this, already at the limit of SATA 3
  13. Xtheblackfox
    Xtheblackfox What's a Dremel?
    28 Nov 2012
    Haha, yea. You will be fine!!
