8800 GTX
Discussion in 'Hardware' started by calib3r, 9 Nov 2006.
  1. calib3r
    calib3r What's a Dremel?
    11 Jul 2006
    Do you think a 550 watt power supply will work with the specs below?
    =Specs=
    ||MB|| ASUS P5LD2 Deluxe
    ||CPU|| Intel Extreme Edition
    ||RAM|| Kingston DDR2 2x 1GB
    ||GFX|| NVIDIA GeForce 8800 GTX
    ||HDD|| WD Raptor 2x 78GB
  2. calib3r
    11 Jul 2006
    Also, do you think a 8800 GTX would fit in this case below?
  3. Guest-18698
    Guest-18698 Guest
    what is that case !!! i would go with a 600w PSU tbh
    and yes it should fit that case
  4. calib3r
    11 Jul 2006
    But the thing is I already have a 550 watt, and that is a Ultra Aluminus case.
  5. overdosedelusion
    overdosedelusion I mostly come at night, mostly..
    29 Oct 2006
    wit the 8800 requiring 2 PCI express connectors, 550 is probably pushing it, you might want to consider over 600. i dont know whether the card will fit or not, i thinks its longer tham ythe 7950 GX2, which is a LONG card
  6. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    what 550 is it? anyone can claim 550. it's the quality.
    You need at least 30a on +12v to power a single 8800GTX.
  7. calib3r
    11 Jul 2006
  8. Krikkit
    21 Jan 2003
    Should be ok. nVidia used to have a list of 8800-series approved PSU's for 100% certainty, but it seems to have 404'd in the last few days. :(
  9. calib3r
    11 Jul 2006
  10. deederdude
    deederdude What's a Dremel?
    26 Oct 2006
    off topic, but kingston is crap - 650W SLI ready PSU is a must
  11. N.A.N.O.
    N.A.N.O. What's a Dremel?
    26 Oct 2006
    If you want to buy a second 8800 GTX it is not enough,
    I would take a PSU with a capacity of approx. 700W, then your are prepared for the future.
  12. Glider
    Glider /dev/null
    2 Aug 2005
    30A * 12V = 360W of GFX power... Am I the only one that finds this rather high?
  13. Guest-18698
    Guest-18698 Guest
    its a power hungry monster
  14. specofdust
    specofdust Banned
    26 Feb 2005
    This thread is so full of crap it's unbelievable. People, take a look at the power requirements of tims bench setup in the G80 review, they used not much more then 300W at full load. Granted there's gonna be a bit more stuff in this box, but I'd be surprised if a 400 didn't cover it, and a 500W most certainly will with space for expansion. Of course SLI changes things, but SLI 8800's are miles out of everyones league for now anyway.
  15. Kevin_G
    Kevin_G What's a Dremel?
    9 Nov 2006
    One thing worth noting on power supplies is that most list there maximum power output on boxes while the Geforce 8800GTX review here tested average continual power consumption. A power supply that is rated for a 400W maximum output may have troubles dealing with a 300W continual output. A 550W power supply (which I assume is maximum output) is recommended by nVidia as takes into account a fairly high end system build with a bit of room to spare in terms of dealing with continual power output.
    Also worth noting is that power supply efficiency changes with its temperature. An open test bench with a low ambient temperature will have a higher efficiency (and thus less power lost in the AC-DC conversion) than in an enclosed case system.
  16. Bbq.of.DooM
    12 Feb 2005
    I meant for the entire system.
    Granted, i'd try to use something with more than 30a. Maybe the enhance ENS-5150, since it's still so cheap and provides 36 amps.
  17. T0MCAT
    T0MCAT What's a Dremel?
    11 Nov 2006
    I went for the antec neoHE 550W
    12V1 38A
    12V2 19A
    5V 26A
    32,9 dBa at 266W/20cm
    efficiency 266W 89%
    efficiency 339W 77,4%
    117 euro
  18. specofdust
    specofdust Banned
    26 Feb 2005
    The 8800GTX in a powerfull bench setup consumes about 320W of power under full load, 800W is overkill by a factor of 2.
    550W should definately be enough for that system. You got fooled into buying a 1.1Kw PSU(sorry, it's harsh, but it's true) - there's no need for others to end up in the same boat though.
