News Adapteva Parallella promises pocket-sized supercomputing
Discussion in 'Article Discussion' started by Gareth Halfacree, 28 Sep 2012.
  1. Gareth Halfacree
    4 Dec 2007
  2. The_Crapman
    5 Dec 2011
    Bet this would be great for folding.
  3. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    bet this would be great for almost anything computer related!
  4. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    i'd get some if i had a need and budget fo custom made software. i dont. surely by the time you spend £50k developing your software... you could have bout some bulldozers.
  5. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Given the press this is getting I was hoping they would have a wider range of examples available online. The performance is promising but the specific details are a bit vague. How does one of these 64 cores compare to say a core in dual/quad core ARM for example? They've shown off a simple math example, but how about something that's a bit more 'Wow!' guys.
  6. Gradius
    Gradius IT Consultant
    3 Feb 2009
    Not impressed at all! Look at the video, is uber SLOW !
  7. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    Yeah, but it doesn't have the GPU muscle the RPi does. It'd be great for...uh...um...hm. Let me get back to you on that. :p
  8. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    For $100, that is actually pretty cheap and a better value than almost any other ARM platform.
    The problem is if the performance-per-watt is worth it. An intel or possibly AMD system might be a better choice in the end. Lets hope phoronix tests this out, they did a pandaboard cluster pitted against some intel processors and didn't prove to be a better investment, although it wasn't explicitly worse either.
    Since this new board has all these cores on 1 system, it's bound to have much better ppw than the pandaboard cluster.
  9. Roskoken
    Roskoken What's a Dremel?
    15 Jul 2011
    Playing pretty fast and loose with the term "super computer" I think.
  10. docodine
    docodine killed a guy once
    10 Feb 2007
    If this is a super computer, what's mine? Future technology?
