Build Advice Advice on an £800 upgrade
Discussion in 'Hardware' started by lunaris, 23 Dec 2010.
  1. lunaris
    lunaris What's a Dremel?
    6 Feb 2010
    Hi all,
    I'm helping my brother upgrade his PC. To cut to the chase:
    Budget: £800
    Main uses of intended build: Gaming, general day-to-day use (watching films, playing music)
    Parts required: CPU, Motherboard, RAM and GPU
    Monitor resolution: 1920x1080
    Storage requirements: N/A, sufficient performant disks being reused from old system
    Will you be overclocking: yes
    Basically, he wants to be able to play most games comfortably at 1920x1080. I've put together the following but would like advice on whether these are sensible and more importantly what GPU I should pair with them (it's unlikely we'll venture into overclocking the GPU):
    - CPU: i7 930 D0 -- £210.52
    - Motherboard: Asus P6X58D-E -- £139.33
    - RAM: 6GB Corsair XMS3 -- £67.12
    - GPU: Uncertain?
    Total cost without the GPU is £416.97. Prices are from scan.co.uk (as of yesterday). I'm aware that sales might make some products better choices over the coming days, so any advice is greatly appreciated.
    Thanks, happy holidays,
    lunaris
  2. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    Wait for sandy bridge. It's only a couple of weeks now.
  3. Remeniz
    Remeniz Muted!
    18 Dec 2010
    That makes sense if the OP were looking at an LGA1156 platform. In this case there's nothing stopping him going for a nice LGA1366 set up.
    Looks pretty good and leaves you enough money for a nice graphics card.
  4. Ljs
    Ljs Modder
    4 Sep 2009
    Why spend the extra though, when a 1155 platform could perform the same or even out perform some 1366 set-ups?
    I second wait, and see how the new socket does toe to toe before spending more then may be needed, saving cash to splurge elsewhere.
  5. Siberdine
    Siberdine Safety Not Guaranteed.
    1 Aug 2010
    You won't be able to overclock your CPU as much if you use a stock cooler. I suggest that you get an aftermarket heatsink, such as a Corsair H50, Titan Fenrir, or the Thermaltake Frio. They range from £30-£55, and they should help keep your temperatures lower, allowing you to overclock further.
  6. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    If he is just going to be using the system for gaming as the only intensive, there is no point in going for i7, he simply won't need the extra power. So, if I were you, I'd be waiting for Sandy Bridge.
  7. Uxon
    Uxon Minimodder
    14 Dec 2010
    +1 vote for that, wait a couple of weeks and SB will most likely offer the best value for money gaming wise.
  8. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    wait for sandy bridge, there is a distinct possibility that sandy bridge chips over clocked (and maybe even without an overclock) will outperform even 1366 oh and as for a GPU GTX 570! Reviews I've seen, read say its a brilliant card, very fast and near silent too, just make sure your psu has enough ooomph and connectors, obviously :]
