Hardware Akasa Blue Aurora
Discussion in 'Article Discussion' started by Guest-16, 7 Sep 2008.
  1. Guest-16
    Guest-16 Guest
    http://www.bit-tech.net/hardware/2008/09/07/akasa-blue-aurora/1
    Today we look at the "Blue Aurora," the new high performance aftermarket heatsink from Akasa. With an exclusively LGA 775 mount and an included 120mm blue LED fan, can the Aurora light up our skies, or will it leave them overcast? Read on to find out!
    :clap:
  2. The boy 4rm oz
    10 Apr 2008
    Looks to be a good cooler. I may pick one up for my brother's PC.
  3. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    I was going to get the noctua_NH-U12 but this looks sweet though I'd prefer a black fan with no glowy bits
  4. The boy 4rm oz
    10 Apr 2008
    It's easy to replace a fan.
  5. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Very nice review... it's been awhile since you folks recommended a cooler over the Thermalright of Noctua so Akasa is definitely on the right track. For those who want a quieter system, they can always pickup Noctua fans and mount them on the Akasa if the Noctua is too expensive (it's not that expensive here in Canada, and can be found on sale for around ~$35-$40).
  6. Red 5
    Red 5 What's a Dremel?
    1 Aug 2008
    But is it worth almost twice the cost of a 965?
  7. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Not sure if Im missing it or not but what is the rated noise on this fan? I can only assume "loud" is about the right amount due to the CFM and the high ish rotational speed.
  8. Baz
    Baz I work for Corsair
    13 Jan 2005
    Although noise ratings do tend to be subjective - different manufacturer's testing setups and equipment etc.
    At full speed it was just about audible over the test rig's fans, but not intrusively so. Obviously with the PWM connector, you'll probably be running a little quieter and you can always easily drop a lower noise fan into the fan bracket.
  9. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    This is probably one of the first coolers that is easy to fit.
    I am also wondering , since the Thermalright U120E is ages old already, did Thermalright made any new cooler solutions that is outperforming their own 120E. For example the True Black 120. Any review in the works for that one?
  10. Baz
    13 Jan 2005
    "Performance is the same for both in single fan mode."
    taken from the site - so not much point then ;)
  11. tonschk
    tonschk Minimodder
    31 Jul 2008
    The heatpipes must be staggered like the Coolermaster Hyper 212 ,to spread better the heat,not in a row one after the next
Tags: Add Tags
