Hardware Akasa Enigma
Discussion in 'Article Discussion' started by Tim S, 17 Mar 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Wasn't this originally the recommended case in the HTPC article which has since changed to a Jou Jye case?
  3. DougEdey
    5 Jul 2005
    I think it should've got 0/10 for performance. It risked destroying the CPU, if you'd had a fry up for breakfast you wouldn't have been fast enough!
  4. Guest-16
    Guest-16 Guest
    Yup - we went on the assumption that other Akasa cases were awesome so this should be - people buy brands after all. Aaaand we called this one wrong :( Mistakes happen :blush:
  5. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    Other reviews of this case seem a bit more favourable (Computer Shopper, for example), which is quite strange. I was tempted to buy this case to use with an Atom board but having reading your review... I won't bother.
  6. BioSniper
    5 Feb 2002
    Fair enough Bindi. At least we now know its a steaming turd :)
  7. quack
    quack Minimodder
    6 Mar 2002
    123°C! OMG!
  8. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    Is that the lowest set of scores anything has ever recieved from bit-tech? I certainly can't remember anything being that bad in the past! If it can't cool an atom what on earth is it useful for apart from a door stop!
  9. Jenny_Y8S
    Jenny_Y8S Guest
    It's not a 100% bad case. It's just a bad case for that sort of CPU. Put in a really low power passive Via cpu into one of these and it'll be a bit better.
    Mini-itx was a format created for embeded boards of low power & low heat. Now we're setting better boards around it requires a bit of re-thinking on the case guys to come up with a good case to allow these teeny boards to be used for something decent!
    My list - make it a little bit bigger, allow 1 3.5" drive or two 2.5" stacked and built in heat pipe for board cooling to move the heat to where you've got airflow.
  10. The boy 4rm oz
    10 Apr 2008
    The case serves it's purpose, can't expect much from a case that size.
  11. Guest-16
    Guest-16 Guest
    It's not just that - the cabling doesnt fit, the SATA drive doesn fit properly and passive EPIA boards make it extremely limited in scope.
  12. Tim S
    Tim S OG
    8 Nov 2001
    An Atom N270 is hardly what you'd call power hungry. Having spent time with the case myself for the impending Ion coverage I'm working on, there are so many flaws and design oversights that you really do have to wonder how this made it out of the factory and onto retailers' shelves. :(
    It's a terrible product, but it does have some merit if you don't install a DVD drive - it doesn't overheat at least.
  13. Vode
    Vode What's a Dremel?
    2 Apr 2008
    123C? Damn, my Atom CPU sits at a happy 40C, although I have my Atom board (the Intel one) in a small ATX case with a nice big fan sucking air across the board.
    (Chipset actually runs cooler than the CPU at 30C, but that's because it's little 40mm fan died after a month or so of 24/7 operation and it now has a vented 80mm feeding onto it.)
  14. SiG
    SiG What's a Dremel?
    3 Dec 2007
    "A - ka -sa,
    easy as...
    1 - 2 - 3 (°C )
    or simple as..."
    Aaand I can't really think of anything more to go with that song.
    It is however somewhat good to see that despite all of Akasa's prior successes, you're not afraid to still tell it how it is. I had somewhat of a concern about this at one point since it seemed that every time I came on bit-tech I'd have to deal with a lot of Akasa praise - which could be the truth for all I know, but unfortunately for me (and others) Akasa isn't all that well stocked anywhere in Australia.
    But seeing that it isn't all sunshine and rainbows when it comes to Akasa somehow actually makes me further consider the option of importing a case because from what I hear, they're very much worth it! (Unless of course they happen to be this one :p )
  15. JEDI23
    JEDI23 What's a Dremel?
    17 Mar 2009
    The Gigabyte board layout is actually the worst case scenario for this case.
    Anything like Intel DQ45EK / FC, Intel D945GCLF2, J&W 7804, Jetway 780G JNC81-LF or Albatron 780G K1780G would do a lot better in terms of thermal performance and cable routing.
  16. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Wow... nice case. :eyebrow:
    I think the best thing you can about it is that it's small. 123°C... impressive. Team that up with a nice passively cooled graphics card around 100°C and you'll have the perfect HTPC radiator.
  17. Guest-16
    Guest-16 Guest
    Mr Jerry from Akasa ;) The Gigabyte Atom board conforms to a standard layout of Atom boards - 99% are the same as this. Gigabyte only changed the colours.
    EDIT: So I've been told the standard Intel Atom boards are 29.5mm high heatsinks but the Gigabyte one is 35mm - the 0.5cm makes a difference apparently, but it still doesn't change the fact that it's got to get air from somewhere.
    The Albatron is the same as a J&W 780G Minix and we tried other mini-ITX boards but we just don't have a cooler that will fit (out of many!! including obviously low profiles). but still, even a wider, v.low profile cooler and fan that you do find to fit will have at least half of it directly sucking off the underside of the optical drive.
    Also the J&W 780G requires a fan over the northbridge heatsink as well in such environments - otherwise it overheats - so Im pretty sure it won't work not to mention the PWM heatsinks too. In fact, it's likely that many powerful northbridges will overheat because you can't effectively remove the heat from that area - regardless of what extra heat using an optical drive above it will generate as well. Imagine trying GPU offloading of a blu-ray movie? ;)
    Regardless of what motherboard actually fits - what about getting the hard drive in? :p
  18. JEDI23
    17 Mar 2009
    akasa has both AMD (AK-CC032) and Intel (AK-CC044) coolers for ITX cases compatible also with Enigma chassis. SATA HDD is best fitted upside down - solves the cable routing issue.
  19. perplekks45
    9 May 2004
    It's got some pretty specific requirements for hardware it seems. Why not just sell it with all the hardware in it already? That way you could prove how good your case actually is and maybe even make some more money.
  20. DeMoB
    DeMoB All of my Dremel wheels are broke!
    10 Jul 2008
    I think there's a typo in the review, last page under the bit about the coolers.
    "Ultra low profile less than 3.7mm(!!?)"
    Do you mean 37mm?
    Dan
Tags: Add Tags
