News AMD’s tri-core Phenom – more than meets the eye
Discussion in 'Article Discussion' started by Tim S, 4 Dec 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. kenco_uk
    28 Nov 2003
    wait.. what?
  3. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    :confused:
    I suppose it'll clear up closer to release time but.. wtf??
  4. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    same boat..... :confused:
  5. Tim S
    Tim S OG
    8 Nov 2001
    The tri-core chips might be a completely different chip to the current quad-core Phenoms, but then there are other things which point to it being the same chip. It introduces a shed load of questions about what all of these codenames are for.
  6. DXR_13KE
    14 Sep 2005
    wait... i got it..... "more than meats the eye", they are transformers and the code names are their real names......
  7. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    me: doing his confused look...
  8. Mister_Tad
    27 Dec 2002
    They may well run out of integers for model names if this is the case.
  9. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    rofl.... yeah transformers...
    tbh im with these guys' boat... have no clue. EXCEPT i now understand AMD's 45nm quad-core with shared L3 = Deneb. thats all i need to know lol.
  10. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    I love writing for a less techy site sometimes - codename free writeup :D
    linkage
  11. wyx087
    wyx087 Multimodder
    15 Aug 2007
    wait, AMD's newly developed 3 core CPU uses the same amount of power as my over 2 month old 4 core CPU??
    god, AMD, do try to keep up
  12. steveo_mcg
    26 May 2005
    Not being funny, but does intel still use a north bridge for the memory controller? If so then of course the AMD cpu power consumption is going to be higher... the intel chip simply off loads some of the heat to a separate chip
  13. Tim S
    Tim S OG
    8 Nov 2001
    As Steveo mentions, the north bridge uses considerably less power on an AMD platform than it does on an Intel platform because the biggest heat-generator (the Memory Controller) is inside the CPU. Also, don't directly compare TDPs - Intel uses 'typical' and AMD uses TDP-max. :)
  14. Clocked
    Clocked Yar! It be drivin' me nuts...
    11 May 2004
    So the processors will have the cores on them but just disabled, I don't get it - why? Surely its a bit of a waste if they are there...
  15. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    My head hurts...
  16. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    Presumably initial stock at least will be processors which have come out of the manufacturing process with a fault on one core, so they disable that faulty one and sell it at a reduced price.
  17. Ben
    Ben What's a Dremel?
    11 Aug 2003
    So they can sell off faulty quad core chips as a dual or triple core chips rather than binning them, but then i dont know how the triple core chips can have ddr2/3 support when quad core chips only have ddr3. so... ???
  18. ssj12
    ssj12 Minimodder
    12 Sep 2007
    so from what I can tell... AMD is releasing these by the time that the QX6850 will be around $500 USD.. honestly not to impressed by AMD's planning. Figured they would release something stronger asap.
  19. kenco_uk
    28 Nov 2003
    Is it Tri-Core because there'll be effectively three different cores on one chip?
    Tbh, it sounds like a pretty mean feat of engineering.
  20. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    tri-core is a we can do this but intel cant
Tags: Add Tags
