News AMD confirms Thuban Turbo Core
Discussion in 'Article Discussion' started by CardJoe, 9 Apr 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    I think it was inevitable that AMD would take Intel's Turbo Boost technology and make their own version of it. It's just a shame that AMD haven't managed any well executed innovative ideas of their own lately.
    I hope for this that they've grouped the cores across the chip - if they group 3 cores on one side of the die or in a corner than you could get a hot spot on the heatspreader.
    On another note, when can we get a picture in these news posts with a link to the full-size?? It's a pain when some of them are really worth a closer look.
  3. scawp
    scawp What's a Dremel?
    8 Sep 2009
    I thought some of the AM2+ series did something similar to this anyway, turning off one core and clocking the other, Its not like they stole this idea off Intel like TWeaK is suggesting, more of an adaptation of their existing technology.
  4. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Quite literally too little, too late.
    I bought a Core i5 laptop with Turbo Boost this morning. If AMD had already released something similar I may have considered it, however I would never have waited for it.
  5. pullmyfoot
    pullmyfoot superbacon
    1 Oct 2008
    that was the other way around. Cores powered down when not in use to save energy. This one speeds them up.
  6. pullmyfoot
    1 Oct 2008
    either way, I wouldnt call it "stealing". its the way technology works. If you see it like that, then Intel "stole" AMD's idea of putting the memory controller on the CPU die. AMD has been doing that for donkey years and Intel only did it starting with i7
  7. zagortenay
    zagortenay What's a Dremel?
    28 Apr 2009
    I overclock as far as I can, without raising the core voltage too much and then enable C&Q. I get more performance without sacrificing too much power usage. Turbo feature is more or less achieving the same goal, following a different approach. It is actually a marketting gimmick, which helped Intel a lot in benchmarks. AMD had to follow the same route and that's all about it.
  8. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    AMD's laptop are crap comparing to Intel's i5 armada... AMD doesn't give much attention to the laptop market...
  9. Goty
    Goty Minimodder
    13 Dec 2005
    Well, that IS why you have a heatspreader in the first place, you know =P
  10. dec
    dec [blank space]
    10 Jan 2009
    Why didnt they just call it Cool n Quiet 4.0 or Cool n Fast or something?
    Any word on whether thuban based quads can unlock to 5 core?
  11. ssj12
    ssj12 Minimodder
    12 Sep 2007
    sorry to say but whats the point? if only half the cores overclock themselves and the other cores shut down, doesnt that decrease performance in most cases? shouldnt this overclock every core like Intel's Turbo does?
    lets take an example of say FarCry 2 since its multi-core friendly. It sends threads to each core. All of the sudden the drivers for the CPU notice need to speed up the process. it kills 3/6 cores. Doesn't that automatically kill the engine's ability to send 6 threads and stop existing threads being processed by the shut down cores? I'd say performance in game would suffer due to this.
  12. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    This is only when you need better single threaded performance. Obviously it's a 'smart' system and will activate based on the load headed towards the CPU. The engineers at AMD are not incapable doddering fools that are incapable of understanding how modern programs work. The fact is that many of the (common) programs we use now are only at most, double threaded.
  13. l3v1ck
    23 Apr 2009
    To be fair my old laptop was AMD, but that was from 2004 when the choices from Intel were:
    Uber expensive but good Pentium M
    Uber hot and inefficient Pentium 4M
    Uber underpowered Celeron.
    I'm glad to see Intel have made good progress when it comes to laptop CPU's.
  14. wilfy1
    wilfy1 What's a Dremel?
    22 Dec 2009
    It seems things have turned full circle. Back when AMD chips were the processor of choice, Intel could only respond with higher clock speeds with all the heat and power consumption problems that went with that. At the time AMD chips did more work per clock cycle so did not need to get into the Mhz race. Now as the article says (will ship at speeds "over 3GHz, substantially" ) they have gone to higher clock speeds. I would like AMD to be competitive with Intel, competition is always good for the consumer, but this just seems a bit desperate.
    I understand you recommend AMD for low budget systems but I don't quite see how this works. Budget AMD motherboards are more expensive than Intel, and while the chips are cheaper I am not convinced by the Price/performance ratio. I am going to try the Phenom dual core unlock to quad core routine but if there was not the possibility of this then I would not have even looked at AMD. As an indication of how things are my supplier is struggling to get hold of AMD chips because his wholesale supplier is just concentrating on volume Intel sales and not bothering with stocking much AMD stuff.
    I hope I have not come across as an Intel fan boy wth this, I cannot however ignore the true situation.
    Perhaps they can generate market share by going ultra budget, they would have to help by reducing motherboard chipset prices to make cheaper boards available.
  15. Xir
    Xir Modder
    26 Apr 2006
    Then again, most games thread particularly bad*.
    Then, when gaming, you get a 500Mhz boost, while working you get all cores...
    Not a bad Idea really.
    *as in, using only 2 cores of a quad
  16. Domestic_ginger
    Domestic_ginger What's a Dremel?
    16 Mar 2010
    I'm looking forward to these. they should market at £165 from what I have heard and should be competitive (and backwards compatable too!). This will probably be my upgrade in 2012.
    Unfortunately AMD has done badly in the laptop market place due thier less efficient chips. I think being stuck with the current generation they can't improve it much more so are holding on for Llano (?codename?).
  17. l3v1ck
    23 Apr 2009
    Actually in the mag they've just switched to Core i3 for the budget system, now cheap but good motherboards are available.
Tags: Add Tags
