News AMD hints at Xbox 720 APU design win
Discussion in 'Article Discussion' started by Gareth Halfacree, 22 Feb 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Harlequin
    Harlequin Modder
    4 Jun 2004
    very interesting ; the part in the PS4 is shaping to be very similar to the 7970m (comparable to a 7850 or so performance wise)
    but
    sony have far greater control and potential useage , with OCL 1.2 they can use any off the 18 CGN cores to do what they want (say 14 for graphics work and 4 for physics).
    if MS have gone a similar route , and once the real potential in the hardware is unlocked , these will be very interesting times!
  3. coolius
    coolius What's a Dremel?
    29 Jul 2007
    At least they are using x86 now which should make PC ports a lot better
  4. The Infamous Mr D
    The Infamous Mr D Minimodder
    11 Feb 2008
    Although that is operating on the assumption that Sony, Nintendo and Microsoft shift a whole load of these boxes. A lot of pundits and sources are commenting that this generation of consoles is coming right on top of a lot of uncertainty about the continued relevance of the 'gaming console' as a device. While it sounds like a nice basket of eggs for AMD (and believe me, I sure hope it is, I am an AMD fan after all), it might be premature to count those chickens before they hatch.
  5. runadumb
    runadumb What's a Dremel?
    20 Jan 2010
    What I really want to know if would Kaveri make for a cheap console in a box? I'm guessing the locked down nature of the consoles would mean more impressive results and the PC overheads would bring it down to less comparable performance (I'm taking GPU not CPU).
    I mean the A10-5800K is under £90. If KAveri comes in around that then something like the steambox could (hopefully) give similar performance for a smallish extra cost.
    Then there's the memory bandwidth issue. The Kaveri wouldn't have anything close to the PS4's memory bandwidth. Which leads to the next question, should these APU's bring back triple or Quad channel memory to feed the GFX parts hunger? Wouldn't that help a fair bit?
  6. Baz
    Baz I work for Corsair
    13 Jan 2005
    Not looking too good for PhysX then. If you can dev for Next-Box, PS4 and AMD PCs via Havok in one SDK, why bother coding in PhysX especially.
    Similarly, AMD GPU performance should really benefit. Consoles are the dominant dev platform, so having deved for AMD GPUs, devs will have to go to added effort to optimise for Nvidia.
  7. towelie
    towelie How do I Internet!!
    1 Sep 2011
    Guys could someone break these specs down for me(or is there not enough information yet).I hearing 8 cores APU with 8GB of GDDR5 memory.Is that not really good spec sounds good but i know there's a lot more to it power consumption lower clock cycles etc.
  8. Hustler
    Hustler Minimodder
    8 Aug 2005
    Why are they being so ambiguous when everyone knows AMD are powering both these new consoles.
    Honestly, there comes a point when an NDA agreement becomes utterly absurd and we're now at that point.
  9. Narishma
    Narishma What's a Dremel?
    21 Feb 2008
    The same reason anybody ever bothered to use PhysX, to get some of those Nvidia marketing monies.
  10. Xir
    Xir Modder
    26 Apr 2006
    my, well they can sure need some good news, their stock level is....appaling:grr:
  11. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    Because, as posted elsewhere in the forums God help you if you try to take the wind out of Microsofts sails
  12. technogiant
    technogiant What's a Dremel?
    2 May 2009
    Wondering if this will lead to AMD skipping DDR4 and jumping to DDR5 on pc motherboards.....If they have developed APU/GDDR5 memory controllers fort use in consoles......why not use them in the pc?...they have been making their own memory modules lately.
  13. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    Even with this news it was one of the worst stocks of the day yesterday :S
    "Shares of semiconductor player Advanced Micro Devices (NYSE: AMD ) slipped 3.7% Thursday, which isn't too shocking, considering that semiconductor businesses were down across the board. Nothing company-specific ailed AMD today, but the fact that the stock is more than twice as volatile as the market means that big swings like today's are far from rare. Despite the fall, if rumors that Sony's new PlayStation 4 will be using AMD's technology prove to be correct, the stock may end up making up some ground."
  14. thogil
    thogil What's a Dremel?
    4 Feb 2011
    GDDR5 is not DDR5. GDDR5 is based on the same tech as DDR3, but it has been optimised for bandwidth at the expense of latency. GPUs benefit greatly from the extra bandwidth, and can deal with more latency, but CPUs are pretty much the other way round.
  15. technogiant
    2 May 2009
    Ahhh....thanks for that thogil.....interesting.
  16. technogiant
    2 May 2009
    So does anyone think the fact that the consoles have gone all AMD will provide AMD graphics hardware on the pc with a real and tangible advantage....even if used in combination with and Intel processor?
    The sort of advantage that it would be worth excluding nvidia from your product selection list?
  17. rollo
    rollo Modder
    16 May 2008
    No sorry AMD need to fix power consumption and noise levels for it to be accepted again. As with the stock 7970 its one of loudest and power hungry cards since Nvidias old 480.
    Personally if I was not watercooling I'd choose quiet over pure performance every day of the week as I struggled to live with the 480s I had before I watercooled them. Heat and noise was crazy, the 7970 stock bears all the same trademarks.
    The fact AMD graphics are in the new consoles bears little relivence to the pc market, consoles are not coded to an Api they are coded to the hardware that is in them. Just because it will have an 8core CPU in it does not mean we will have multicore games.
    Hyperthreading as been in existence for years now and is still unsupported by games, we may see more games finally use 4 CPU cores with the new consoles but we are not going to see a 6 core CPU getting maxed in a game.
    Direct x is still the biggest thing holding back pc graphics and it will always remain the case till the overhead that the Api uses is removed. And OpenGL died in the eyes of publishers years ago so its not even an option :(
  18. Kodongo
    Kodongo What's a Dremel?
    29 Feb 2012
    (Source)
    :rolleyes: :rolleyes: :rolleyes:
  19. rollo
    rollo Modder
    16 May 2008
    Seems to top the 680 in everything no? Did say 7970 stock not custom editions.
  20. TimB
    TimB What's a Dremel?
    19 Sep 2006
    Actually, there are two possibilities. The next Xbox, or the SteamBox.
