Hardware AMD Phenom and Quad Core Opteron
Discussion in 'Article Discussion' started by Tim S, 14 May 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Tyr
    Tyr Minimodder
    7 Jun 2006
    No good to me as I'm one of the people stuck on S939 :(
    Got an S939 machine because I thought it'd be arround a while, as did many others.
    Even so, looks rather good but I want to see real performance figures and prices before making a decision. At the moment it is just a PR information war.
  3. Guest-16
    Guest-16 Guest
    Yup. Hence the conclusion ;) Can't wait til we actually get a piece of hardware :thumb:
  4. DougEdey
    5 Jul 2005
    There's a lot of good tech coming through by the looks of it. Shows that AMD may be able to pull of a huge comeback.
    But 45nm will be the biggest selling point in my view, especially with graphics cards requiring half a sun worth of nuclear power.
  5. bjrcboy
    bjrcboy What's a Dremel?
    26 Feb 2006
    Man I wouldn't mind building a octa core phantom system but then I read AM3 next year. I've been waiting for the R600, erm HD 2900xt?, to come out but I might as well wait longer. Just wait for the card thats coming out to replace the R600, isn't it coming out a quater or two after it anyways? Then get a DDR 3 board, Octa core, and as many gpu's as possible. Watercool it and then I'll be out dated in a few weeks oh the joy! haha. (its 344am and I havent slept in 26 hours excuse the grammer and spelling =))
  6. Almightyrastus
    Almightyrastus On the jazz.
    21 Mar 2002
    Looks awesome on paper, but then again these things always do.
  7. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Sounds good, although I don't like the sound of the backwards 'compatibility', seems silly to buy a new CPU but its not going to be much quicker/ efficient because your motherboard can't be fully updated to the new standard...
  8. culley
    culley What's a Dremel?
    12 Jul 2006
    I can't wait till these cpu's are out, i will be sticking with intel and the core 2 duo untill then but i have a feeling AMD will be out on top next year and will give intel a run for there money.
  9. Guest-16
    Guest-16 Guest
    Better that then a new socket. It allows for systematic upgradability: upgrade your CPU, keep your motherboard. Then later upgrade your mobo.
    You may not be in a position to reformat and reinstall for a new board, but require quad core power.
  10. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Step-by-step upgrade? Seems interesting, even though I don't think I'll upgrade any time soon.
    Maybe you should re-read that one. :)
    However, this creates an inherent performance problem since both dies are only connected through the CPU fronst side bus (FSB). Ah, sounds better.
  11. TheEclypse
    TheEclypse What's a Dremel?
    11 Aug 2003
    Pages 4 and 5 have done a runner :confused:
  12. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    precisely
    I have an X2 4200+ and 'upgrading' to a 6000+ when i can overclock almost as high seems a bit of a waste, but this, may well be my upgrade path. Its a bit concerning that AM3 is coming out so soon afterwards, iguess i have two choices...
    Upgrade to an AM2+ CPU, keep my current rig as-is, then upgrade the mobo to an AM2+ mobo next year, again, keeping my GPU and RAM, or wait for all of this and buy a AM3 system when that arrives next year.
    Either way, the resale vlue of my system is going downhill day by day. I sometimes wish i had bought C2D, but being a bit of an AMD/nvidia fanboy, that just aint gonna happen. The little man needs my support, even if my bucks dont get me exactly the same performance as the big-blue.
    The one thign that doesn't fit into all this is the AMD/ATi acquisition. I know its long in the past now, but it still seems really bizarre, ATi was better on Intel platforms, and in the 939 period, nvidia was the AMD cpu buyer's weapon of choice, my how things change.
    It will be interesting to see the performance difference between an AM2+ CPU on a system like mine, and a similarly specced machine on an AM2+ motherboard. I'm sure there's lots of us that need this info before spending huge amounts of money on new tech. Especially as like me, there are loads of us that WANT to stick with AMD.
  13. AcidJiles
    AcidJiles Minimodder
    19 Jun 2006
    actaully in the price point battle amd is still good in the mid - mid high range. with core 2 duos have i admit a longer life expectancy but atm in comparison to amd mid range offering they have a higher price for performance point.
  14. Guest-16
    Guest-16 Guest
    AM3 will only be bringing DDR3 to the mix in a year. You'll still keep all the benefits of AM2+ in it though, and DDR2 will still be far cheaper and more efficiently clocked than 3.
  15. GoodBytes
    20 Jan 2007
  16. Guest-16
    Guest-16 Guest
    No idea what happened to K9, but Barcelona is K10.
  17. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    i will wait for AM2+... currently at s939 now, so i wont buy AM2 just to be outdated in a few months. but i wont need AM3 either...... Barcelona here i come!! :D
  18. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Interesting and cool stuff, but all these incremental upgrades worry me a bit. A64 is getting old now and AMD should probably start thinking of a redesign sometime soon.
  19. djDEATH
    23 Mar 2006
    umm - did you read the article? thats what this was all about, a redesign, and name change
  20. culley
    12 Jul 2006
    I think he means a redisign of the K8, which isn't going to happen.
Tags: Add Tags
