News AMD Phenom hits 7GHz
Discussion in 'Article Discussion' started by Claave, 29 Nov 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    Awww the poor 580 :)
    Impressive overclock but obviously no chance of us getting speeds like that at home!
  3. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Poor 580, RIP.
    And before anyone says anything Its a Modified 580.
  4. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    Pshhh, what are you talking about I run Crysis at those clocks on a regular basis! No problem there duuddeeee
  5. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Wonder if 7GHz fixes the stuttering in COD Black Ops...
  6. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    of course fermi blew up.. that was expected!
  7. Centy-face
    Centy-face Caw?
    26 Apr 2009
    Ha genius! Love it.
  8. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    wow awesome
  9. CAPSLOCK
    CAPSLOCK Lost in Time and Space
    4 Oct 2009
    Nice, but can it play Metro 2033?
  10. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    I'm running that too at the moment - only getting 43 fps at the moment. How much are you getting
  11. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    91fps in an gtx480 16x aa, no lag
    i7 3.8 ht off last time testing (test with it back on see if any stuttering still the game does support muticore and ht as well)
  12. dactone
    dactone dact-one
    26 Apr 2010
    could someone work out how fast 7ghz is in mph?
  13. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    7x10E9 x 45 x10E-9 = 315 m/s
    (315 *602) = 1134000 m/h
    1134000 / 1000 = 1134 km/h
    (1134 / 8) * 5 = 708.75 MPH
    roughly as conversion to mph isn't exact.
    Not that there is any scientific basis for the above i just made it up.
  14. salesman
    salesman Minimodder
    29 Apr 2007
    Yes 7GHz is fast, but can it make the Kessel Run in less than twelve parsecs?
  15. Altron
    Altron Minimodder
    12 Dec 2002
    It's so powerful that it makes units of distance become units of time.
  16. bobwya
    bobwya Custom PC Migrant
    3 May 2009
    6.944GHz is not 7GHz. The sorry should be entitled 'AMD Phenom nearly hits 7GHz but fails'...
  17. Dr. Strangelove
    Dr. Strangelove What's a Dremel?
    13 Mar 2005
    Or... 'AMD Phenom hits 7,1GHz, although slightly unstable '
    But I guess that might depend on which side of the fence you sit on ;-)
  18. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    what i don't get is how the 2nd highest overclock was another phenom II x4 at 6.5ghz, but why is it that i rarely hear about the chips reaching 4ghz on water cooling? and if i7 can reach 4.1ghz on air, then shouldn't it theoretically pass 7ghz when cooled with liquid nitrogen?
  19. Vigilante
    Vigilante What's a Dremel?
    30 May 2008
    Intel's chips no longer have high clock speed ceilings, mainly due to their architecture. Intel learned its lesson with Netburst (which I believe they predicted would scale to 12ghz, and was therefore designed with low ipc but high clock speed in mind), whereas i7 and core based chips simply can't handle those speeds.
    However, considering the current state of affairs, it's reasonable to presume that an i7 would not need to reach as high a speed to be competitive in terms of performance, so in reality it works itself out.
  20. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    showerhead, never would have guessed 7ghz is almost speed of sound
Tags: Add Tags
