News AMD Radeon RX 480s prove flashable to RX 580 specs
Discussion in 'Article Discussion' started by Gareth Halfacree, 20 Apr 2017.
  1. Gareth Halfacree
    4 Dec 2007
  2. adidan
    25 Mar 2009
    This makes the 580 pricing all the more bonkers.
  3. Vault-Tec
    30 Aug 2015
    It's looking like it rarely works though, and you lose your Displayport on certain cards.
    You would need a card that is able to maintain at least close to the clocks of the 580 or it will just crash when loading up games.
    The 580 is nothing but a binned and slightly refined 480 any way.
  4. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Slight grammatical/lexical errors. Feel free to delete this post once found to be helpful, or indeed unhelpful.
  5. yuusou
    yuusou Multimodder
    5 Nov 2006
    1- Grab a second hand 480 and flash it.
    2- Increase overvoltage, cooling and credit card limit for power bill.
    3- ???
    4- Profit!
    N17 dizzi likes this.
  6. Vault-Tec
    30 Aug 2015
    That would be very hard to achieve, because just in order to keep the stock 580 clocks stable you also need to tweak the software. So basically if you sold it to some one they would put it in their PC and it would crash, meaning you'd get it back.
    As I said, the 580 is a binned and slightly refined 480. What I mean is as AMD continue on making these Polaris chips they will get a bit better and will slowly start to clock higher meaning they've refined it. Same as anything really, CPUs, GPUs etc. They may then be binning them too to make sure they are fully stable at those clocks.
    A 480 is not the same, thus you will probably have to ramp the fans up etc to cope with the extra heat clocks and voltage.
  7. Gareth Halfacree
    4 Dec 2007
    The 'of' is optional when saying "comes courtesy [something],' and I can't see any change you've made to the other emboldened section of text - but I'm perfectly happy to assume I'm just being dense.
  8. adidan
    25 Mar 2009
    Got a dual bios and you don't have much to lose in trying I guess.
  9. N17 dizzi
    23 Mar 2011
    Fair enough. I found the first sentence I highlighted not very clear, which is most likely me being dense.
  10. Gareth Halfacree
    4 Dec 2007
    How's this: 'the process is as simple as flashing RX 580 firmware - but there's one major caveat [...]'?
  11. N17 dizzi
    23 Mar 2011
    Perfect! Feel free to comment on my professional performance from your armchair. I shall try to maintain the same level of patience.
  12. Gareth Halfacree
    4 Dec 2007
    Hey, I welcome it - if something's unclear (or, as I frequently do, I've dun goofed with a typo) then please do point it out so I can make it betterer!
  13. Vault-Tec
    30 Aug 2015
    True.
  14. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    FTFY! :thumb:
