News AMD rolls drivers into Steam
Discussion in 'Article Discussion' started by CardJoe, 17 Sep 2010.
  1. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Lol i just tried it out and catalyst install manager crashed,so i think ill stick to the old fashioned way for now however i think its a neat idea.
  2. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    Nvidia are updating their install package with the current Beta drivers. You will be able to perform a "clean" install where it does not just overwrite the old drivers but performs a full driver clean first - all automatically.
    This seems more like a killer feature than driver updates through Steam - which to my mind is not desirable on any level.
  3. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
  4. wyx087
    wyx087 Multimodder
    15 Aug 2007
    just used Steam to update my drivers. zero problem, and very easy. count the mouse clicks:
    Steam menu -> Update AMD driver (auto downloads) -> install -> finish
  5. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    If steam automatically detects a game you have installed would benifit from a newer driver, then this is awesome. Otherwise, I don't want to be bothered by steam every month a new driver is released.
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    Problem with the article, red camp is now Pantone 347..
  7. bbshammo
    bbshammo What's a Dremel?
    23 Mar 2008
    Aha, in that case you appear to assume that Nvidia actually have consumers at the heart of their efforts?
    Do we need reminding of the countless times they've bled Nvidia fans by re-releasing old tech under new badges, simply because they thought they could get away with it?
    I stopped buying green a long time ago. Back since the ATI 9800 pro release I think.
  8. greyhavens24
    greyhavens24 What's a Dremel?
    23 Oct 2009
    A BRILLIANT IDEA
    I tried downloading the Steam drivers but stopped a short while in. I noticed that the download package was 115MB compared to 74MB from ATI. I can only assume that the installer from Steam covers all versions of Windows whereas I just downloaded the version I required for my machine.
    However, that aside this is a step in the right direction. We're getting a step closer to console like ease of use. I don't think that this is necessarily aimed at enthusiasts who will essentially do what I did, but for the more casual gamer who has less technical knowledge it is a step forward definitely. Well done AMD/Valve - brilliant idea.
  9. matt...
    matt... Slacker
    18 Nov 2009
    don't know about 'less technical' but it certainly appeals to the 'more lazy' gamers like myself :)
  10. Xir
    Xir Modder
    26 Apr 2006
    And that while Steam detects which Card you have, and could select the "optimized" driver. Instead you get a gigantic download.
Tags: Add Tags
