News AMD's Radeon HD 6990 is in our lab
Discussion in 'Article Discussion' started by arcticstoat, 28 Feb 2011.
  1. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Nope. I couldn't care less about multi GPU cards. I can't be doing with driver support issues in games.
    I just want a single GPU that works well first time, every time.
  2. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    looks like the motherboard is the Gigabyte X58A-OC (263.5 x 304.8mm) so the card must 30cm +/- long.
  3. crayfish
    crayfish Amazing scenes!
    3 Dec 2002
    Balls to this. WHere is the 5770 successor?
  4. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    The PCI-e connector is presumably a standard length, so you could always compare the length of that with the length of the card. I doubt the card is any longer than a 5970, in any case.
  5. Gradius
    Gradius IT Consultant
    3 Feb 2009
    Not a GPU, more like a TANK!
    Cannot wait to see the bench results.
  6. Synalar
    Synalar What's a Dremel?
    7 Feb 2011
    The test card has real luck-Bindibandgi is not there to dismantle it as he did with some other top offerings (Asus MARS,...)
  7. DwarfKiller
    DwarfKiller What's a Dremel?
    25 Nov 2010
    Shame, was looking forward to Bindi's destruction streak.
  8. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    doing a rough estimate on that pic
    nm measuring the wrong end xD say 29.6cm, 11.67075" yeah 30 seems to fit
  9. phinix
    phinix RIP Waynio...
    28 Apr 2006
    30cm I say...
  10. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Your complaint will have to be mostly with the game developers on that one. Both green and red teams have support out for multiple monitors, just plug and play up the maximum supported by your card(s) for the most part. The game developer just has to make the game take advantage of those extra displays. As already mentioned, there are already games that use multiple monitors and they don't require any special hardware functions.
    There's just no incentives for developers to add such support. Very few gamers use 2 monitors, let alone 3+. You see Eyefinity because it's all AMD: they can stretch any game whether the developer has added support or not, you just might get HUDs and such split. Supporting it just means allowing for movable HUD elements.
  11. paisa666
    paisa666 I WILL END YOU!!!
    4 Mar 2009
    hmmm, I moded my case to fit any card they throw, but damn this thing looks huuuge!!!!... AMD surely will take the lead again with this
  12. red4our
    red4our ¿Qué es un Dremel?
    13 Jan 2011
    From the image, it looks like 2 x 8-Pin connectors. Looks like I'd have to swap my CM690 for a suitcase to fit this card. :D
  13. Supersnake
    Supersnake What's a Dremel?
    1 Mar 2011
    When the card can power an IMAX theater in my living room I might consider it.
  14. jprykov
    jprykov What's a Dremel?
    29 Oct 2010
    when quad gpu mobos were released, the problem is where to look for a case that could fit those mobos. the problem now is what case will it fit on that card. i dont know if my case now (xaser vi) could fit that big ass card!
  15. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    It's called the 6870.
  16. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    Finally I can retire the 4870x2!!!
    3 monitors is now the standard for PC Gamers!
  17. Pete J
    Pete J Employed scum
    28 Sep 2009
    :confused: Err, really?
  18. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    How much is it? Anyone???
  19. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
  20. urobulos
    urobulos Minimodder
    13 Apr 2010
    Bleh. I am not a fan of multi monitor setups. Had a chance to see one in action for about 15 minutes and there is no way I can feel immersed by a game on separate screens. And to be honest, anything above a GTX 570 is overkill for modern games even for the rich among us who can afford 30" screens. Sure this card will be faster, but who cares if you are getting 80 instead of 60 fps at max details. What makes me a bit sad is how hardware manufacturers have to push gimmicks like Eyefinity in order to justify those uber cards. Let's face it, vast majority of PC titles do not push the ultra high end cards at all so the only way to justify them is to artificialy increase the resolution you are playing at. Can't get excited about these until we get games that actually take advantage of that extra oomph on a single screen. That or 4k displays/projectors. :)
Tags: Add Tags
