Motherboards Any thoughts on the MSI 770-C45?
Discussion in 'Hardware' started by Singularity, 10 Jun 2009.
  1. Singularity
    Singularity ******* Operator from Hell
    2 Mar 2008
    Trying to make a build for a friend, and I've come across this motherboard, so now I have some questions.
    First of all, the build would include the Phenom II X3 720, 2*2 GB of DDR3 and... now I need a motherboard. Unfortunately, I live in the worst county in the world (TM) and the selection of AM3 motherboards is, at best, laughable. I can't find a single available motherboard within a normal price range, except for this one. Other boards are much more expensive and include things that my friend doesn't need, like crossfire support, HD audio, the SB750 and such. He wouldn't OC apart from a small bump to the multy, but I'm guessing that's just the matter of the BE cpu and not the SB? Please correct me if I'm wrong :)
    Unfortunately, I can't find any reviews of the MSI 770-C45, so, no idea how it performs in real life. The price seems very good, and the specs are right on the money. All in all it seems like a very good deal.
    Any info on the board, and of course any tips and advice, is more than welcome :)
  2. Singularity
    2 Mar 2008
    *bump*
    Anyone? Maybe?
  3. Orionche
    Orionche Guest
    Too late now! Already ordered. :]
    Was searching for a review myself, and google came up with this. :eek:
  4. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    I'm just polishing off a review of the 770-C45 for the next issue of Custom PC right now. Without giving too much away you shouldn't have any cause to regret buying one :thumb:
  5. thedroyd
    thedroyd What's a Dremel?
    17 Aug 2009
    This may be a silly question . but I am confused by all the various AMD cpus. Will a Phenom X4 9950 (not a Phenom II) work in the 770-C45 board? It seems to support almost everything else...
  6. javaman
    javaman May irritate Eyes
    10 May 2009
    It won an award when customPC reviewed it. All AM3 MSI Boards came up trumps it seems. Gigabyte and specifically the Asus CrosshairIII Formula all got good scores too. Seems all I do not is quote customPC >.> /waits for lawsuit.
    Nope, AM3 board use DDR3 memory. Only phenomII and athlon II can use DDR3 memory. They can also use DDR2 so both can run in AM2+ boards with a proper bios update however. Phenom I and Athlon I can only use DDR2 memory. HOpe that helps
  7. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    770-C45 is AM3, and DDR3, so no, it won't support AM2 processors. Phenom IIs with DDR3 support only need apply.
  8. thedroyd
    17 Aug 2009
    Phenom on 770-c45
    Thanks guys - I missed that in the myriad of specs :sigh:
  9. Orionche
    Orionche Guest
    Been working great for the last two months since i had it. (if anyone is interested, cpuz specs)
    Running XP SP3 on it and had no problems whatsoever since the first boot. Don't intend on tweaking anything on it yet, as I hope to have it for a longer period of time. :)
    BTW, the whole rig is cheap as hell... ^^
  10. javaman
    10 May 2009
    Orionche I think your ram is only running single channel instead of dual.
  11. FOADA
    FOADA What's a Dremel?
    23 Aug 2009
    I plan on buying one of these boards, according to the specs I should be able to run a set of 2x2gb patriot 1600 memory. My question is, the specs they put out was for the 9-9-9-27 timing ram...would the higher grade 7-7-7-20 or 7-7-6-18 suffice or would it be too much for this board..?
  12. Guest-16
    Guest-16 Guest
    Welcome!
    It's not down to the motherboard, it's down to the CPU quality. The motherboard should provide it with enough CPU-NB voltage to do 7-7-7. Im pretty sure it has the option, but I cant remember off hand
  13. Orionche
    Orionche Guest
    Yes... Singularity pointed out that to me just today. Being a hardware noob for some things (and not keeping up with tech), I have no idea how to make it dual channel (if its up to me, anyway >.>)
  14. Guest-16
    Guest-16 Guest
    It's not single channel, it's in Unganged mode that treats each memory controller as a single 64-bit controller. It's better/more efficient for multitasking and multithreaded apps, but if you're benchmarketing then ganged gives bigger numbers.
  15. Orionche
    Orionche Guest
    Hmm... I switched a chip from slots 1 & 3 to 1 & 2 and its in dual channel now, says cpuz. Haven't noticed any performance boost, tbh... though, i can't remember the benchmarking numbers i did with everest a few weeks ago, so... :)
  16. Guest-16
    Guest-16 Guest
    Fair enough :)
    Should have looked what slots you are using haha
  17. Carper
    Carper Guru
    19 Aug 2009
    To make it dual channel you match the colours right ?
  18. Guest-16
    Guest-16 Guest
    Yup
  19. Elton
    23 Jan 2009
    Quite Idiot proof no?
  20. Guest-16
    Guest-16 Guest
    Not necessarily. MSI used to colour it so you had to put one in each colour. One colour designated a channel so for dual channel it was two colours.
