Other Any 'vapers' out there?
Discussion in 'General' started by Sentinel-R1, 13 May 2013.
  1. digitaldunc
    digitaldunc What's a Dremel?
    4 Oct 2010
    Ah, my Kick2 is authentic, as I couldn't find a clone that does 15W :D
    I'm not dripping as much as you do which might have something to do with the difference, as well.
    Expensive yeah, but I'm getting that clones are inconsistent, to say the least. These kayfuns are seriously p-ing me off -- I've just rebuilt one and it's vaping like a champ, but I bet tomorrow morning it'll be dry hit city. I'm pretty much settled and happy with my gear and juice now, I just wish it would work properly, damnit :D
    I also wish the proper high end stuff was priced more reasonably -- surely you shouldn't have to pay the earth for a decently milled piece of tube? It'd help if half the stuff was actually available as well...
  2. jrs77
    jrs77 Modder
    17 Feb 2006
  3. rak500
    rak500 Minimodder
    22 Aug 2009
    I went through the same kind of stuff... I tried different RBAs, cheap and genuine stuff, but really can't justify the 70 squids tag on the Kayfun when I have a kayfun clone that works oh so well for a fraction of that price...
    This said, I couldn't agree more with the Atmizoo mods, I have a Dingo, a Guppy/Bayou and the Lab and there are worth every penny in terms of build quality and durability. Bottom switch are always a pain ergonomically for me!
  4. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    Holy crap this stuff smells bloody marvelous:rock: got to wait until Monday to try it :waah: stupid steeping.
  5. jrs77
    jrs77 Modder
    17 Feb 2006
  6. jrs77
    jrs77 Modder
    17 Feb 2006
  7. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    HELP PLEASE!
    Just started on e-cigs and am looking for something that lets me add my own liquids as opposed to buying replacement cartomizers. Also I need to know if it can be shipped internationally to me as I'm in Africa.
    I saw at the beginning of this thread that the starter kit on ecigwizard was recommended, but I need a whole bunch of accessories and liquids to last me at least a couple of months.
    Would anyone care to list a kit and also the accessories for me? I have no idea what I'm doing.
    This is what I have in mind so far, which might be total garbage for all I know.
  8. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    What I've used since November and is still going strong is the following;
    1) Joyetech eGo Vivi Nova SLIM StarterKit Double - €52
    2) VG Unflavoured 125ml - UK Sourced - 5.4% (54MG) - €26.53 (125ml bottle)
    3) VG Base - 100ml x 2 - €4.26
    4) Coil Heating Haead Unit for Clearomizer Vivi Nova CC 3.5ml (x6) - ~€12
    5) 10ml empty plastic bottle with safe needle - €0.71
    All-in, it's cost me €120 and I have enough liquid and wicks to last me over a year.
    Worked a treat for me so far. I make my own DIY mix, making it weaker every time I refill the bottle. It may not be as high-tech as some of the setups here, but I'm more than happy with it and it's saving me a fortune.
  9. digitaldunc
    4 Oct 2010
    Nealieboyee,
    The general consensus seems to be that the EVOD starter kits are the best to get going with, although I'd say the 650mAh batteries that are included are a little on the small size. In any case I'd avoid CE4/5 type clearos, the ones I've had have been terrible.
    Tobacco flavours are pretty hit or miss and don't generally taste like cigs, most people end up ditching them for something else.
    In any case I'd recommend trying a variety of liquids before you commit to ten bottles of anything that may potentially be too weak/strong for you, and you don't like the taste of.
    HTH :)
  10. Nealieboyee
    14 Aug 2009
    Thanks man. So If I order say THIS, is it as simple as just adding a few extra clearomizers and my eliquid of choice?
    I'm looking for at least a couple of months supply, and if anything should break/die then I need to make sure I have extras. The coil is built into the clearomizer isnt' it (on the one I linked)?
    Edit: Ninja'd. Ok so I'll stay away from the CE4and 5's. I'm not in a position to try liquids as I live overseas and we don't even have a McDonalds here. E Cigarettes/Vaping here are non-existant, unless you're using disposables.
  11. saspro
    saspro IT monkey
    23 Apr 2009
    It's not a bad kit to start on. I'd add a couple more clearo's or a proper tank (like the protank or protank mini) as those CE5's have a habit of dying quickly
  12. Nealieboyee
    14 Aug 2009
    Which part of those clearo's dies? If its the coil, am I not better off with something that I can change coils on?
  13. Nealieboyee
    14 Aug 2009
    I'm not worried about price at the moment (to a degree). I just want something that works and will work for a long time. Liquids I can take care of. But everything else is a bit daunting. Its like looking at watercooling bits!
  14. digitaldunc
    4 Oct 2010
    Indeed, you'd be looking at EVOD/Protank/Nautilus or similar for replaceable coils.
    Nautilus is generally recommended as the best tank system with pre-built coils but they are quite expensive compared to other tank systems.
  15. saspro
    saspro IT monkey
    23 Apr 2009
    A protank or protank mini with a pack of replacement coils (go for 1.5 ohm ones) will last you a while and give good results.
  16. Nealieboyee
    14 Aug 2009
    How does this look? Reliable? Added a steel tank because I'm scared of dropping glass....
    In addition to this do I just need liquids?
  17. saspro
    saspro IT monkey
    23 Apr 2009
    Should work nicely
  18. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    someone needs to put together a list of things newbies should buy - as I'm in the same position as nealieboyee. I want one of these fancy mechs but I have no idea where to start! I need to stop smoking the cigs :)
  19. jrs77
    jrs77 Modder
    17 Feb 2006
  20. mrlongbeard
    31 Jan 2010
    I'd go for an MVP and a protank mini.
