Graphics Anything better than 560 Ti TWIN FROZR II under £200?
Discussion in 'Hardware' started by simeonipicker, 30 Aug 2011.
  1. simeonipicker
    simeonipicker What's a Dremel?
    18 Jul 2009
    My 4890 is starting to show it's age and I'm looking for an upgrade under £200.
    Going by Custom PC/Bit-techs review, is there anything better than the GTX 560 Ti TWIN FROZR II for under £200?
    Regards
  2. David164v8
    David164v8 Minimodder
    29 Aug 2011
    I suppose you could try a 6950? But they are fairly similar in performance.
  3. t4n6o
    t4n6o You know when you've been tangoed
    16 Aug 2011
    it depends on your budet really and if your happy with ati or want nvidia - as mentioned the 6950 is about the same and the 6970 is better but if you want nvidia, what about the 570?
  4. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Gtx 480 performs better (on a par with a 570). but unless you watercool it, its loud and gets hot.
  5. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    Simple answer is no, 560ti's are brilliant card's, as good as a 570 when overclocked (although obviously you could overclock a 570 to get 580 performance) also (assuming your in the uk) it seems to be very hard to get hold of any ati/amd card above the 6870, hence the 560ti is a very good and pretty much your only choice right now :)
  6. simeonipicker
    18 Jul 2009
    Looks like 560 ti it is then! Thanks for replies
  7. ElZog
    ElZog Defeater of Satan's Transformo Sofa
    14 Jun 2007
    In case you haven't ordered yet, the Twin Frozr III version of the 560Ti just popped up on Scan. Only £10 more (so £190)
  8. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    What about the DirectCU 2 version of the 560Ti?
  9. simeonipicker
    18 Jul 2009
    Which has the best cooler? Frozr 3 or direct cu? Luckily, i haven't purchased yet :)
    Regards
  10. ElZog
    14 Jun 2007
  11. David164v8
    29 Aug 2011
    Looks like the Frozr has a better cooler. I'd go for it. No point spending much more.
  12. Bede
    Bede Minimodder
    30 Sep 2007
    It certainly does have a good cooler, my idle temps are 30C with the TF3 fans at 40% :)
