Displays AOC Q3279VWF
Discussion in 'Hardware' started by Guest-23315, 27 May 2018.
  1. Guest-23315
    Guest-23315 Guest
    Hi All,
    I need a decently sized minitor at home, basically for document work, the occasional movie, and further down the line, gaming.. It will be primariy run by my XPS13 via a Thunderbold to HDMI adaptor. (for the next few months)
    I was looking at more expensive Dells, but came accross the AOC Q3279VWF - and I cant work out why a 32" 2560x1440 monitor is so cheap.
    I know it doesnt have a VSEA mount which will be a pain future, but can anyone give me a reason to not buy this over anything else? it fits the bill and is a stupidly good price.
  2. TheMadDutchDude
    23 Aug 2013
    It will be using a TN panel, guaranteed. The viewing angles won't be great, so make sure that you can sit directly in front of it for the best viewing experiences.
  3. Guest-23315
    Guest-23315 Guest
    Hexus review says its damn good for the price - so ordered.
    Guess it can be gifted to Parents in future if I get a better one.
    EDIT - before this I was on a 2007 24" non-ultrasharp Dell, so IPS vs. TN doesn't really matter all that much for me
    TheMadDutchDude likes this.
  4. spolsh
    spolsh Multimodder
    4 Feb 2012
    Great for the price. Prone to some ghosting, but if you look on the web I'm sure there's some settings that help a bit. Got my nephews one each at Christmas, and it's a damn site better than their old 1080p screens.
    Oh, the stands a bit flimsy but it does the job.
    Guest-23315 likes this.
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    It is an MVA screen that launched at £200 MSRP late last year, so just a crazy good price (and likely to be a gamble on quality in regards to backlight bleed and so on, but if OP gets it from amazon then that doesn't matter as they don't fight against returns).
  6. Guest-56605
    Guest-56605 Guest
    I have one, it runs @75Hz flawlessly on an Nvidia 1080Ti - in terms of bang per buck it's a steal @Mankz.
    Guest-23315 and TheMadDutchDude like this.
  7. Guest-23315
    Guest-23315 Guest
    Brilliant. Thanks all.
    Bought via Scan, as I can pick it up from Currys on Ken High, rather than weekend delivery, or getting it to the office.
  8. Guest-23315
    Guest-23315 Guest
    Also, you can get a VSEA adaptor for this: here
    Looks like its just a caddy for the standard alu base, but you could hacksaw the remaining piece off.
  9. Guest-23315
    Guest-23315 Guest
    This is on a Today Only on scan:
  10. Guest-23315
    Guest-23315 Guest
    Ok, for £200, this screen is so good its a joke...
    BUT - the box STINKS of Chinese Factory, and whomever designed the screw in base deserves to be shot. Its useless. And will be VSEA'd. BUT. The screen is amazing.
  11. Vault-Tec
    30 Aug 2015
    I've had a couple of AOC and each time I have been bowled over by what I got for my money.
  12. spolsh
    spolsh Multimodder
    4 Feb 2012
    I told you it wasn't a good stand.
    But yeah, first one I put up I thought WTF ? Why ?
  13. Guest-56605
    Guest-56605 Guest
    Yup, the box is as you say, I can get my hands on said firearm but the panel...
    The panel is mind blowing value for money :thumb:
  14. Big Elf
    23 Apr 2009
    I've been needing a new monitor for a while, read the reviews on this a couple of months ago then saw this thread and the latest discount and I've ordered one too at £177.
    Vault-Tec likes this.
  15. TheMadDutchDude
    23 Aug 2013
    I just wish it had a faster refresh. Damn it!!
  16. Guest-23315
    Guest-23315 Guest
    Don't say we didn't warn you about the Stand being pants...
  17. Big Elf
    23 Apr 2009
    I don't tend to move them around so as long as I can put it on I'll be OK.
    Which is the best connector to use for this resolution or doesn't it matter? I'm currently using an HDMI to DVI cable (1920 x 1080) and have Dual Link DVI-I, HDMI and DisplayPort 1.2 ports available.
    Edit: I RTFM. I need DisplayPort or HDMI cables to get the refresh rate of 75Hz otherwise it'll be 60Hz with a DVI connection.
  18. Big Elf
    23 Apr 2009
    Wow, just wow
  19. Vault-Tec
    30 Aug 2015
    Fastsync. Unless you are daft enough to be using a Vega GPU :D
  20. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    This monitor would probably be spot on for my RX 480.
