News Apple sued over display quality
Discussion in 'Article Discussion' started by Da Dego, 21 May 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. Paradigm Shifter
    10 May 2006
    I'm not going to jump to conclusions one way or another, but out of interest, how long have you had your MacBook, Brett?
    It's entirely feasible that there has been a product refresh, or panels are now being sourced from a different company, and that's the problem. I guess it depends how long this has been 'in the works' for... something which I don't know, so again I'm just speculating. :)
  3. leviathan18
    leviathan18 What's a Dremel?
    17 Mar 2005
    what paradigm says is true if you take as example dell... they first revision of lcd usually have ton of issues banding leaking dead pixels etc... after 2 o 3 revision the lcds are great maybe is the same with this mac book
  4. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    but backwards it seems
  5. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Somebody optimized their screenmaking process a bit too much and it backfired?
  6. Paradigm Shifter
    10 May 2006
    Actually it works both ways. I seem to remember that one of the new Samsung widescreen panels used an 8-bit display when it was released, and when they updated it slightly it started using a 6-bit instead...
    Might be remembering it wrong, though.
  7. PA!N
    PA!N What's a Dremel?
    16 Jul 2005
    Some people have waaaay to much time on their hands... :duh:
  8. GoodBytes
    20 Jan 2007
    Well of course Mac OSX has worst graphics then Windows Vista....
    Look, everything on the MacOS is white... you have 1 color! :p
    I'm just kidding here.
  9. konsta
    konsta What's a Dremel?
    2 Jul 2005
    I'm guessing that not enough readers of this particular site own a macbook to canvas a real variety of opinions..
  10. GoodBytes
    20 Jan 2007
    Well you don't see many Mac over-clockers and Mac gamers these day's ;)
    ---- OFF TOPIC ----
    Yes it's a bit off topic but link a bit.
    In my opinion, Apple should STOP doing Mac computers, they should simply sell MacOS for anyone to buy. This it's great!
    People that cannot afford, and don't see the potential or usefulness of a high-end computer (eg: my parents, you of course don't play games, and do computer programing), and go with a low end computer, and also go with a nice MacOS ...OS, were it's easy to use for them. And people that would like more flexibility and gamers, or simply like the Windows look-and-feel can go with Windows.
    Apple can still make their iPhone and Ipod (and uTV.... I mean eTV... I mean TV X3000, I mean iTV now)
    Mac or PC's are just as stables (hardware wise), and they both work with 1 and 0's, why should they be apart. Apple can gain a bigger market this way, and MS will have competition (which is good for any industry and consumers)
    ------ END -----
  11. Glider
    Glider /dev/null
    2 Aug 2005
    I suggest you take a dive in the Apple forum... And be surprised...
  12. woodshop
    woodshop UnSeenly
    14 Oct 2003
    i'v had a MacBook Pro for all of 5 days now, and i thing the Glossy screen looks great.
  13. Firehed
    15 Feb 2004
    Odd, I only noticed a grainy look on my MBPs screen when it's in Windows (and only via Boot Camp which I've long since uninstalled). Except for the dust under the screen that conspicuously showed up after sending in the thing for service (and even more the second time, utterly failing to remove the first bit that I pointed out).
  14. phantomxc
    phantomxc What's a Dremel?
    7 Dec 2004
    Ive seen the problem once out of the what...500 macbooks I've repaired....Replaced the lcd and it was fine. Personally I think the macbook pro lcds are horrible...
  15. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    I own a macbook. Havent noticed any issues with the screen. But its not my usual laptop, so I havent used it *that* much.
    But then again, I dont believe they are good enough to advertise as superior to all the other ones out there. I find my Dell XPS M1210 about the same as this one. But I guess I should try it in daylight as well before making up my mind.
Tags: Add Tags
