Hardware ASUS Eee Keyboard PC Review
Discussion in 'Article Discussion' started by Sifter3000, 2 Aug 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. memeroot
    memeroot aged and experianced
    31 Oct 2009
    if only it was android :-(
  3. Canon
    Canon Reformed
    19 Jul 2010
    A nice concept is all really, I can never see myself having a genuine use for one either but I said the same about the Ipad and it certainly didn't flop. Have to admire ASUS' optimism though.
  4. alexandros1313
    alexandros1313 What's a Dremel?
    22 Jan 2007
    It reminds me of my old Amstrad CPC 6128 :)
  5. SaNdCrAwLeR
    SaNdCrAwLeR What's a Dremel?
    1 Feb 2008
    I'd totally go with ubuntu for netbook edition on this one :eek:
  6. BlackMage23
    BlackMage23 RPG Loving Freak
    4 Aug 2006
    I don't think going with Windows XP was a good idea, a customer linux distro would have been better, or even windows 7.
    Did they really need to put an atom in this? I'm sure they could have used something else that is low powered but with a bit more grunt.
  7. memeroot
    31 Oct 2009
    @alexandros1313
    10 run "starcraft2"
  8. wyx087
    15 Aug 2007
    excellent idea, but a bit early in execution.
    wait a bit, wait for ARM Cortex-A9 dual core chips, then put on a Linux distro designed for media centre.
  9. StephenK
    StephenK Sneak 'em Upper
    21 Dec 2006
    If I had the spare money I think i'd buy one even just for the rightness of using it as a C64 emulator :)
  10. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    I would love one of these as a media PC keyboard/mouse/universal remote, if only they released it just as that.... tacking on a full OS is just wrong for this type of device
  11. Tom @ CCL
    Tom @ CCL AKA: Yewen
    10 May 2010
    Its been heavily delayed and design was originally started before Windows 7 was available, due to this I doubt it was economically viable for Asus to start work on a new UI etc for Windows 7.
    When the device was originally announced the Atom was the best choice, the trade-off for a ULV Celeron of the same era wouldnt have added up. Especially if you consider the battery life is poor like the review suggests it could be using just an Atom chip.
  12. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    so.... how easy is it to install an OS of your own choice?
  13. eldiablo
    eldiablo What's a Dremel?
    13 Jul 2005
    I guess it would have made more sense to reverse the roles and put the atom in the receiver side and send out the picture to the keyboard. This way you would have a wireless keyboard with a touchscreen and the batterylife could have been a lot better.
    Perhaps add a usb port for expansion purposes, plugging in a usb stick or something.
  14. sear
    sear What's a Dremel?
    2 Aug 2010
    It's such a shame that this thing is basically useless if you want to play HD video.
  15. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    i don't look at this as a independent device, but more of an epic control device.
  16. Creekin
    Creekin What's a Dremel?
    31 Aug 2003
    I want a combination of this, the Optimus Maximus and the Logitech G19.
    nice idea eldiablo, how about dual cpus. remote and local?
    you paying attention asus? :D
  17. Burdman27911
    Burdman27911 What's a Dremel?
    26 Mar 2007
    Only issue is that you can't be portable... with the current design you can take the keyboard to another room and plug it up to a monitor to use the PC there, then easily move back to the living-room where your receiver is for wireless display. If you move the CPU to the receiver end, you are stuck with only displaying to whatever the receiver is hooked up to (which may not be a bad limitation in some situations).
  18. Faulk_Wulf
    Faulk_Wulf Internet Addict
    28 Mar 2006
    "The display is capacitive and accepts simple multi-touch gestures in specific scenarios but it doesn't use 'typical' pinch/twist smartphone style ones due to Apple patents."
    How can you copyright something as vague as pinch and twist?
    Seriously, I'm really asking, and I'm really ticked off.
  19. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Honestly I'm not even sure what this does. But whatever it is, it's a very nicely designed piece of kit (aesthetically at least).
    It's a beautiful piece of gear!
  20. Blackie Chan
    Blackie Chan What's a Dremel?
    5 Nov 2009
    they should have called it an EEEboard
    I can see a use for this if i was doing a lot of mobile writing, pero otro que eso... maybe programming if you dont want to debug right away, or notes if you do that on a compy
Tags: Add Tags
