Motors Axle Stands and 'Modern Motors'
Discussion in 'General' started by GreatOldOne, 23 Nov 2010.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Right. I need to do some work on Kitty the Jag (Replace front wishbone bushes - £150 if I do it, £900 if Jaguar do it :eyebrow:)
    The work requires dismantling the suspension, so I need the wheels off - So ramps are a no go. Which means axle / jack stands are the only option.
    The problem is placing them correctly - not an issue on the Gooster, as it has chassis / frame rails. The Jag, on the other hand, is a monocoque like most modern cars.
    I can place stands at the jacking points, but I don't want to damage the underside of the car or any pinch / spot welds under there. Any suggestions? I've seen some people use ice hockey pucks attached to the axle stands with a grove cut in them to accomodate the weld seams, but I'd like some other options / opinions before I hoist nearly two tons of Coventry's finest up in the air...
    How have you supported a car without front wheels in the past? Over the top, unsafe and / or Redneck solutions need not apply. :)
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Strap a pair of jetengines to the front wingmirrors and point them skywards.
    Oh wait.
    Do you know anyone who might have access to a car-lift? That would seem to be the easy solution.
  3. Teelzebub
    27 Nov 2009
    Does it have a front cross member if it does that would be a good place.
  4. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Jack points, engine cross member.
    Just for gods sake work on the side of the car not under it if at all possible - even though axle stands can be safe things do happen, you don't want a sudden hug from your car!
  5. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    also with the stands, put the wheels under the car, should it fall with you are under the car, would stop car from crushing your head
  6. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    What ^^ said. My parents had a caravan. When it went into storage by dad removed the wheels and jacked it up on prop stands, during this process the caravan fell off the jack (stupid git forgot the trolly jack and was using a bottle jack) with the main axle / cross member crushing his ribs on one side. He's still not perfect mabey 3-4 yrs later but he's alive, GOO, don't be a dick like he was.
  7. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Jackpoints or engine crossmember, it's what the former are for after all. If you are particularly paranoid about damaging weld seams, the hockey-puck thing seems like a good idea. I've used hacked-up rubber doorstops in the past.
    GreatOldOne likes this.
  8. Krikkit
    21 Jan 2003
    To protect jacking points I just use a couple of bits of soft wood - gives a bit of cushioning to the underside. My jacking points have a worrying lip on them to slot the jack onto, very easy to crush and end up with a nasty rusty bit.
  9. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    In soviet Russia we turn car on side.
    In all seriousness, one side at a time mate, axle stands aren't the best on modern cars but they're safer than leaving it on a jack. I would also chuck a mofo amount of ballast in the boot of the car to shift a load of weight backwards, meaning less downward force at the pressure point on the chassis.
  10. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    I'd love to see the maths to show how much weight you would need when the pivot is so close to the rear!
    julianmartin likes this.
  11. Burnout21
    9 Sep 2005
    one man sat in the boot is enough to reduce the loading at the front jacking point, You sir haven't jacked a car enough. With 4 friends it was possible to change a wheel without a jack as they lifted the jack with the car! lol!
  12. GreatOldOne
    29 Jan 2002
    Thanks chaps.
    I won't be leaving it on a jack whilst I work - hence the stands.
    And with the weather suddently getting a lot colder, It doesn't look like I'll be doing it any time soon. :)
  13. Krikkit
    21 Jan 2003
    Suspension bushes are such a ballache, I've got to attempt a polybush session on mine sometime soon but it's such a fiddle I haven't plucked up the courage. :p
  14. GreatOldOne
    29 Jan 2002
    Yep - I know.
    It's obviously a ball-ache for Jaguar as well, as the reason it's so expensive is they change the whole wishbone & control arm, rather than the bushes! :rolleyes:
    Obviously jag techs don't know how to press out bushes...
    I can replace all of the lower wishbone / contol arm bushes for £150 if I take the arms & bushes to a friendly independant, or I may just bite the bullet and buy my own press (I've seen decent 10 ton jobs for £150 - so I'd still be 'saving' £600 if I go that route)
  15. Krikkit
    21 Jan 2003
    Problem with buying a press is that although it's nice to have tools it probably won't get used so often.
    With the Pug bushes they don't really need pressing out, they can be manhandled instead, but it's still hard work.
    £900 seems a bit steep, I suppose it's a good premium for 'em. They'll send off the arms and wishbones somewhere and recondition them so they can flog them back to you later! :hehe:
  16. Xir
    Xir Modder
    26 Apr 2006
    I'm with you on that one, I've got to check my turbocontrolvalve and it's hoses, but I stopped after meddling about in the sleet for ten minutes :miffed:
  17. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Goo, how much would it be at a smaller garage? Might be worth it for them to take on the annoying stuff.
  18. GreatOldOne
    29 Jan 2002
    Dunno - I tried ringing the only independant Jag specialist near me (in Milton Keynes) to get a quote, stating exactly what needed to be done (I got a report from the Jag Dealer in Northampton during Kitty's last service), and didn't get a straight answer.
    He just kept saying, "I need to see it to estimate it" - well, no, not really... Just give me a ballpark. It's suspension work. Bushes. You must have done it before... But no.
    I'll be sourcing the bushes myself, as they're available online from JustJags, so they only thing I need to know is how long it'll take, and what they charge per hour. :rolleyes:
  19. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    So you add a barrel and turn it into a cider press, voila at least a couple of months use every year :clap:
  20. Burnout21
    9 Sep 2005
    what jag is it? If its an X-type then you must already know its pretty much a Ford mondeo, so any ford specialist could do the work.
