Guide Beginner's Guide to Machining Plastics
Discussion in 'Modding' started by Captain Slug, 17 May 2005.
  1. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    I don't recommend using lasercutting for plastics. Most of the machine shops I've talked to that offer laser cutting simply won't do that kind of work with anything other than aluminum, steel, or titanium. It's also just not a cost effective method and in most cases takes more time to do correctly than it would with standard tools.
    Water-jet cutting on the other hand I have had done with plastics and you just have to keep the thickness tolerances in mind.
    I have extremely limited experience with Acetal, Delrin, and Nylon. I left them it out since they are considerably more expensive than the other materials listed. It's not something I felt I should include in a beginner's guide. You are correct in that they're ideal materials for load-bearing or frequent wear applications. Neither of which instances an entry-level machinist would presumably be capable of designing said parts.
    Also, Acrylic is equally as dangerous when it comes to fume production at certain temperature ranges. It also begins producing fumes at a lower temperature than polycarbonate. I don't recommend using flame polishing for either unless you have a serious filtration mask and a ventilated work area. As a standard it's best for most people to simply use sanding and polishing since the more "convenient" methods required exprienced hands and controlled environments in order to be safe.
    Nothing you mentioned are items I feel would be reasonable to include as recommendation for the entry-level machinist for safety and experience concerns so I have omitted them.
  2. kplonk
    kplonk What's a Dremel?
    1 Mar 2002
    Thanks for the info, nice to have all in one place
  3. r00t69
    r00t69 What's a Dremel?
    2 Apr 2005
    Thanks for the guide Captain Slug.
    I've often found and handheld carpenters plane is very good for finishing straight edges once you set the blade fairly shallow.
  4. Agent11345a
    Agent11345a What's a Dremel?
    10 Aug 2005
    I did a project where I chose to machine plexi with a CNC mill, be sure that if you use one of those you do an initial cut of about .025 inches down and then bring it down in about .125" each additional cut until it is done, takes a hell of a long time, but the result is well worth it.
    also bear in mind that the plexiglass needs to be put in place very securely (the tension put on the mill is very high)
  5. Captain Slug
    25 Nov 2001
    Added template making guide.
  6. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    This is an insane guide, Captain Slug! I'll most definately be using it! :O
  7. Rage.
    Rage. What's a Dremel?
    3 Mar 2007
    simply fantastic.
    thx =]
  8. Captain Slug
    25 Nov 2001
    updated materials list and added small sections on milling, lathing, and lasercutting.
  9. trati629
    trati629 Can I Fix It? :$ Well Yes??
    13 Jun 2005
    Another Glue to use for welding Acrylic ect..
    I like to use Tensol 70 for welding most plastic together
    available in the uk at
    RS: Componants
  10. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Great Guide Captain Slug. Thanks for sharing :thumb:
  11. Cheapskate
    13 May 2007
    I'd like to add something here...
    If you have one, a tile wetsaw works great. The older the blade, the cleaner the edge. I have actually sliced my fingers on freshly cut plexiglas. I can vouch for polypropylene and acrylic.
    I can also say it WILL NOT work for Lexan... I tried to cut Lexan with a tile saw out of curiosity and ended up kicking a breaker.
  12. Sushi Warrior
    Sushi Warrior What's a Dremel?
    20 Mar 2009
    You sure mitre saws aren't usable with acrylic? I just cut a sheet of acryl with it and it worked fine.
  13. capnPedro
    11 Apr 2007
    Nice bump of a 4 year old thread (yeah, yeah 2 years since last reply...).
    A good cut is actually more dependant on the blade used, so if your mitre saw has a high TPI blade, well good for you, but most people use [compound] mitre saws for ripping wood.
  14. Sushi Warrior
    20 Mar 2009
    Oh damn, it was a sticky and I forgot to check the dates :blush: :blush: :blush:
    And I think the acrylic might of actually hurt the blade, it doesn't seem to cut as well anymore. Woopsies!
  15. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    I use a non-ferrous TCG blade for plastic sometimes.
  16. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    Just a little request for update: Alibre Express is no longer available. The sire redirect to the trial for the normal Alibre.
    If you are a collage student (or know any one with a .edu email) you can grab many of Autodesk's tools, including Inventor, Maya, AutoCAD,etc for 15 months.
    Link: http://students5.autodesk.com/?nd=register&und=624
    Also, you can grab SolidWorks' Engineering Stimulus Package (basically 90 day Student version)
    here: http://www.solidworks.com/sw/esp/engineering_stimulus_package.html
    I realize that many here use SketchUp, but imo, SolidWorks and Inventor are much better (esp. for design work). As for rendering, SolidWorks and Inventor have quite a decent renderers built in.
    Note: On SolidWorks you can do quite decent renderings. Here is a personal example done by me in about 5-10 minutes:
    http://www.flickr.com/photos/24351647@N07/3395904616/
  17. sejutaluka
    sejutaluka What's a Dremel?
    23 Nov 2007
    good info, request permission to bookmark this thread. thanks
  18. Stormwulf
    Stormwulf A mod to far?
    5 Mar 2009
    Just seen this, nice guide but be cautious of gases given off.
    For example acetals give off formaldahyde gas so make sure you do it somewhere well ventillated or you'll end up with stingy eyes and a bad chest as the least of your problems.
    Also there is an ABS FR which is flame resistant and tolerates higher temps ( abs should be available in most any colour you can think of ).
  19. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    Just on the topic of jigsaws, you can get special blades for acrylic/perspex. I found these to be much better than the metal blades I had be using previously, they cut straight with ease and leave a finish which looks semi-polished.
    Bosch T101A are the blades I used.
  20. thegoody
    thegoody What's a Dremel?
    11 Nov 2010
    Great set of info there, will definitely come in handy! Cheers!
