Other Bespoke battery pack help
Discussion in 'General' started by Shirty, 9 Mar 2013.
  1. Shirty
    18 Apr 1982
    Hey folks, I'm having a few issues getting my head around replacing a small battery pack I have. The pack in question is simply labelled "Ni-MH 3H260BC 3.6V +".
    Here it is, I've removed the outer wrapping to reveal the layout:
    It comprises three Vinnic H260BC batteries. Now I have three problems. Firstly, it looks like this is a bespoke layout. Secondly, I can't seem to find a UK source for replacement individual cells. Thirdly, how the hell does the soldering work on the surfaces of these cells? The strength of attachment is awesome.
    I'd really like to source a pre-assembled replacement unit (using similarly rated alternative cells). I figured some of the RC crowd on here might know quite a bit about this stuff.
    Any help much appreciated, it'd be great to get this secret item working again after several years. :thumb:
  2. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
  3. Tangster
    23 May 2009
    Looks like spot welding, not soldering.
  4. Shirty
    18 Apr 1982
    Thanks mate, I'll fire them an email to see if they are familiar with it.
    I'm sure you're spot on, I know nothing about most things :hehe:
  5. KID52
    KID52 Minimodder
    19 Aug 2007
    You could probably get away with replacing it for a single cell LiPo, only issue would be if you have a charger for LiPos or not.
  6. Shirty
    18 Apr 1982
    The charging is fully controlled by the circuit board in the picture, it has a DC jack attached to it for a 4.5v 300mA AC adaptor.
    Also the space the battery pack will need to fit in to will require a very similar sized replacement.
  7. KID52
    KID52 Minimodder
    19 Aug 2007
    Are you certain the board does the charging? You could always hook the battery to the DC jack directly to allow for external charging, and you could certainly get a LiPo to fit. I'd definitely consider it if you can't find a suitable button cell replacement.
  8. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Defiantly spot welded, you need very high heat in an extremely short time span as to not damage the cell.
  9. lilgoth89
    12 Mar 2011
    well if he is replacing the batteries i dont think he is to bothered about damaging the cells ;)
    also he could always snip the wire just before the battery and replace it with a similar cell
  10. Burnout21
    9 Sep 2005
    It not some much damaging the old cells, but if you try to do the new cells then he should know the risks.
    Having said that, using a soldering iron to remove the old tabs would result in a cell popping which isn't fun!
  11. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
  12. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Call Strikalite - They'll make you anything you want. If you can either email them that picture or tell them the cell type over the phone, they'll most likely be able to make it for you.
    I use them for custom airsoft battery packs all the time, they're reasonably priced and decent people.
  13. Xir
    Xir Modder
    26 Apr 2006
    Battery Packs are generally spot-welded and not soldered, which makes them a pain to replace (in wireless screwdrivers for instance)
  14. Shirty
    18 Apr 1982
    Thanks for all your help gents, I've contacted the companies recommended and pointed them to this thread, so hopefully I might get lucky :)
  15. monkeyharris
    monkeyharris What's a Dremel?
    14 Apr 2004
    This looks like a Mathmos Aduki board and battery if I'm correct?
    Did you get anywhere with the replacement battery? I'm in the same situation trying to replace mine.
    Thanks
  16. Shirty
    18 Apr 1982
    Bizarrely yes it is, and although I have a company trying to source batteries of the same dimensions and capacity to create a pack, nothing has yet come of it :(
  17. monkeyharris
    14 Apr 2004
    Ah ok, well if you have any success, please do post back here.
    I was thinking I might just buy three separate coin ni-mh cells and solder/glue them together, cover in heatshrink/electrical tape?
    Code:
    Abit like these guys do here: http://bigsislilsisblog.tumblr.com/post/11703828179
  18. andalucito
    andalucito What's a Dremel?
    30 May 2016
    Hi there, it is indeed a Mathmos Aduki.
    I have the same issue right now. My battery just died and i was wondering if replacing it with a Ni MH 80 mAh 3.6 V would work?? i have seen them online for less than 3 euros.
    I have no experience at all in the area.
    Thank you very much.
  19. David
    7 Apr 2009
  20. Shirty
    18 Apr 1982
    :hehe:
    I never did bother to get it sorted, I just use ours plugged in now. It's really just a nightlight for my daughter, so no issue using it like that, but it would have been nice to sort.
    I suspect (without looking) that this tread ranks fairly highly on a Google search for "aduki battery replacement" or similar...
