Graphics Best Gfx for 1920x1080
Discussion in 'Hardware' started by deathtaker27, 24 Dec 2010.
  1. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    hey guys,
    which graphics card is best for this resolution, as well as which manufacturer to buy from
    thank you guys :)
    DT.
  2. Pete J
    Pete J Employed scum
    28 Sep 2009
    Well, it depends how much you're willing to spend and what you want to do with it! I'll assume you want to run games.
    The cheapest card you should buy is a 1GB GTX 460 for £140
    If you can spend more, I'd recommend a Radeon 5870 for £206. I highly recommend you go for this card as the price is incredibly cheap at the moment. Not only that, you get Aliens Versus Predator thrown in, which is a pretty good game in my opinion.
  3. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    ew, I had that particular 5870 for a week or two in June. My end of exams present to myself. There was a buggy bios and a bad cooler that meant it was noisy, and it has a custom pcb which means you can't overvolt it.
    Avoid if you can.
  4. Pete J
    28 Sep 2009
    Well then, 460 it is!
  5. GoodBytes
    20 Jan 2007
    In today's gaming, max max settings, 60fps: a Geforce GTX 260 is all you need.
    For tomorrow games, a Geforce GTX 560 (not out, not official name, no details released. But you know what I mean), or on a budget and available now: 1GB Geforce GTX 460.
  6. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    yes i know what you mean, the budget is erm plenty to say
    whats the 570 like worth it?
  7. Bakes
    4 Jun 2010
    that's what we like to hear :D
    570's good. Reasonable price, good performance. Can't tell you much more than that personally - I do however own its bigger brother and that seems good enough.
  8. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    Bascillu with graphic cards the more you spend the more you get, and then remember heat and noise issue and the fact you'll see diminishing returns in performance per £ as you go up the scale.
    If moneys no object a 580/570. Otherwise moving down a 6950, or 460.
    Also if you buy today bargain alert
    http://www.overclockers.co.uk/showproduct.php?prodid=GX-147-XF
    A 5870 for £180
  9. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  10. Pete J
    28 Sep 2009
    I'd go for a 570 then. Here's a good one.
  11. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
    Yea. Just received mine from DPD Santa :D
    5850 plus overclock should handle pretty much anything at 1920 res, if people are not crazy about Crysis, Metro2033, ArmaII that is :eek:
  12. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    not heard of KFA pete who are they?
    and this will be going into a sandy bridge build, getting everything i can before the vat rise :)
    DT.
  13. wyx087
    15 Aug 2007
    KFA were UK branch of BFG, when US BFG went bust, UK guys found Galaxy and basically Europe arm of Galaxy.
    cards are manufactured by Galaxy, branded under KFA across Europe and warehouse is somewhere in Wales.
    if i were buying nVidia card, apart from big motherboard manufacturers, i'd go with either KFA or Zotac. don't go with Palit/PNY as closest RMA centre i can find is in US.
  14. Uxon
    Uxon Minimodder
    14 Dec 2010
  15. RnkBajin
    RnkBajin What's a Dremel?
    10 Nov 2010
    I just received my new KFA GTX 570 yesterday, overclocked it last night to 825 (the highest it would manage and still remain stable without extra volts) and it's not a kick in the a**e off of a stock 580 and all for £150 - £200 less. Highly recommended!
  16. dactone
    dactone dact-one
    26 Apr 2010
    wow 5850's are coming way down now i might get another one
  17. Pete J
    28 Sep 2009
    What wuyanxu said!
  18. Zeus-Nolan
    Zeus-Nolan Minimodder
    2 Feb 2008
    European brand of Galaxy
  19. bagman
    bagman Minimodder
    18 Apr 2009
    i would go for a 570gtx by evga if you can afford it
  20. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    is evga worth the extra £30
