SketchUp Bit-Tech Digital 3D Render Gallery
Discussion in 'Modding' started by scooby, 6 May 2009.
  1. Tangster
    23 May 2009
  2. cronicash
    cronicash What's a Dremel?
    25 Aug 2009
    First time having a little go at characters, i realize that not all the normals in this model are correct.
    WIP!
  3. Genghis
    Genghis What's a Dremel?
    8 Apr 2011
    one piece eye?
    have you try a three pieces eye for more realism and more depth?
  4. cronicash
    25 Aug 2009
    yeah good point, theres allot of things i missed...
  5. Genghis
    8 Apr 2011
    good thinking
    good light simple mod but with precision.
    great shader on bracelet
  6. LithiumDesign
    LithiumDesign 3dsMax User
    23 Jul 2009
    Long time no speak, I've been working on another interior, but I've got BIG problem...
    Been away from my PC for a few days - came back today to carry on modelling more furniture and editing some materials etc, took a few test renders and everything was going perfectly. I went to do a larger render, around 960x540, bumped up the shadow/reflection precision and the FG... As the FG completed and went into rendering, the render froze and 3ds max shut down! An error message popped up saying; "Unhandled Exception" and these were the files 'involved' -
    acmindump.dmp
    dmpuserinfo.xml
    dumpdata.zip
    I re-opened the scene, thinking I had pressed something I shouldnt have and the same thing happened again... I then went back to some previous versions of the scene, with lower render settings and simpler models and the same error came up?!!?!
    Very annoying! Have any of you experienced this before? I'm running 3ds max 2010 64-bit and using the mentalray that came with it
    I've searched for this problem on google and I haven't found any solutions, apart from re-installing 3ds which hasn't been proved to remove the problem :(
    On another note, renders look amazing and cronic your renders are amazing!
  7. cronicash
    25 Aug 2009
    tried to make a better version...
    Three piece eye yet i think i left the specular layer far too close to the interior of the eye...
  8. cronicash
    25 Aug 2009
    i might give up on characters, dam hard. Very envious of those that have the nack for it...
  9. LithiumDesign
    23 Jul 2009
    cronic, I think you're suffering from a case of too detailed too soon, go back to basics and make some simple human shapes in proportion first, then focus on adding details! You definately have the knowledge in the software to be able to model organic models!
    cronicash likes this.
  10. cronicash
    25 Aug 2009
    Last one, i very much agree^^
  11. password
    password What's a Dremel?
    28 Dec 2010
    these pics are good :D
  12. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    made this yesterday to try out another "studio" background
  13. cronicash
    25 Aug 2009
    nice model. Is it levitating?
  14. Dark~3nergy
    14 Jan 2007
    thx, but no, it's standing on spikes
  15. cronicash
    25 Aug 2009
    Whats the diameter of the fans on the front and back?
    Just curious as compared to the intel stock cooler...
    Pretty cool, almost like making a mini itx look wacked out like a larger case ...
    22.7 mm diameter fans by any chance?
  16. Dark~3nergy
    14 Jan 2007
    those are 40mm fans. 22.7mm fans are too loud and don't move enough air imo.
  17. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looks awesome Dark! is that just a concept or will we be seeing it come to life? :D
  18. password
    28 Dec 2010
    that looks awesome :thumb: i want one
  19. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    Thats so cute darky, what kind of material should it be made of ? acrylic etc ?
  20. cronicash
    25 Aug 2009
