What on average do you lot get? Does having a quick CPU mean a quick boot time? Or is it generally down to how fast your HDD is?
My boot time is under 30 seconds. Fast cpu = fast boot. Fast hard drive = fast boot. Ram drive = crazy fast boot. There are some boot time optimizations like clearing out the startup folder that will make your boot significantly faster. If you want it even faster, try a Raptor, or ram drive.
Mother-Gooser, Gigabyte iRam IIRC My boot time (Power on [push button] to workable system) is 28 seconds, on a 1,5GHz Centrino lappy with 512MB RAM and a 5400RPM HD Things that, in my experience, influence boot time are (in order) Speed of HD, Amount of RAM, Speed of CPU To a lesser extent, Startup Folder (unless you load huge programs), and tweaks... Also, a huge speed killer is setting your CD-rom as bootable device before your HD (in BIOS)
Ah yes I had seen the iRam, I thought BBQ was reffering to actual drives, the iRam can only support up to 4 or 8 gb I think, and thats a costly lot of ram, and not enough to install an OS on either, nuts
8GB is plenty for my Gentoo system and IIRC it didn't have to be high speed ram, PC2100 or so was more then plenty.
it's 4gb. Yes, real ram drives exist. I know for a fact that puget can hook you up with an 8 gig ram drive for about 500 bucks. Compared to that, the iRam is rather pricy.
About 1 minute, but I have an extra BIOS to load(and it confirms my RAID is doing A-ok) and my system is kinda over-used.
You have loads of crap loading on boot. How many processes running at boot? fwiw, have a stripped xp install which boots in ~ 10 secs once dmi pool verification. About 3/4 a scroll of the bar/ 2k3 server is similar.
About 30 seconds from hibernate. Only real IDE Flash drives are these http://www.mini-itx.com/store/?c=16#2621 but they're expensive and store next to nothing. Afaik the only proper flash drives you can get are in laptops. <A88>
my 4000+, 2GB tightly timed, and 250GB, 7400RPM SATA started up in a minute and 12 seconds but then again - look at all the **** i have installed http://img.photobucket.com/albums/v349/Shouryuu/Desktop.jpg
