CPU bored so lapped my 2600k
Discussion in 'Hardware' started by jizwizard, 6 Sep 2011.
  1. jizwizard
    jizwizard Modder
    24 Dec 2010
    as title said i was bored
    as you can see from the pics it was not exactly flat.
    could not get it to a perfect mirror finish as i had run out of 2500 grit paper but hey ho
    managed to drop the temps on my cores from
    core 0 43c - 36c
    core 1 38c - 33c
    core 2 48c - 37c
    core 3 38c - 32c
    not bad going for an hours work
    http://forums.bit-tech.net/album.php?albumid=1541&pictureid=21933
    http://forums.bit-tech.net/album.php?albumid=1541&pictureid=21934
    http://forums.bit-tech.net/album.php?albumid=1541&pictureid=21935
    http://forums.bit-tech.net/album.php?albumid=1541&pictureid=21936
    http://forums.bit-tech.net/album.php?albumid=1541&pictureid=21937
    http://forums.bit-tech.net/album.php?albumid=1541&pictureid=21938
    Guest-44432 likes this.
  2. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    Thats impressive really, 5+ degree drop in temps, what cooler are you using?
  3. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Nice Work! Not that far off a mirror finish.
    Did you cover the back of the CPU to stop any metal filings getting in?
    You hit the jackpot with that chip, nice overclock of 5.1g.
    I got a poor one I need to pump lots of volts to get it to work stable at 4.5g
  4. Huge
    Huge aka Dave
    11 Jul 2011
    Nice, might do this to my 2500k when I change the cooler.
  5. jizwizard
    jizwizard Modder
    24 Dec 2010
    using a h60 at the minute. the chip will hit 5.4 but needs monster volts
  6. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    What voltage gets you 5.1GHz stable?
  7. jizwizard
    jizwizard Modder
    24 Dec 2010
    1.52v thats with hyperthreading on. the chip overclocks like hell but needs the voltage
  8. Nealieboyee
    14 Aug 2009
    Wow...Out of interest, how far did you get with the intel max safe vcore (is it 1.4v?)
  9. jizwizard
    jizwizard Modder
    24 Dec 2010
    it will run at 4.8 but for that extra i need to start throwing voltages at it. had 1.6 through it before and had no problem with heat
  10. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    1.6v!!!!!!!!!!!!!!11111111one lol That's more than 3dfx.voodoo was pumping through his i7 3800k on ebay :hehe:
  11. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    You do realise that with 1.5v+ your chip will be dead within a couple of months...
  12. jizwizard
    jizwizard Modder
    24 Dec 2010
    no it wont lol. have used these voltages since the chip was released. as long as the temps are ok ill be fine. famous last words:hehe:
  13. jizwizard
    jizwizard Modder
    24 Dec 2010
    somebodys got to push these damn chips.
  14. megadriveguy
    megadriveguy Minimodder
    19 May 2010
    1.6v is ****ing crazy
    Your chips not gunna last long at that, but if it goes you can always buy another I'm sure you already know that's crazy volts
  15. jizwizard
    jizwizard Modder
    24 Dec 2010
    yes it is crazy but i run it at 1.5v for everyday use. only push it when benchmarking. not that 1,5v is not high enough already
  16. noizdaemon666
    15 Jun 2010
    I like how from an innocent post about lapping it's managed to end up being a thread advising jizwizard to lower his vcore RIGHT NOW OR THE CPU'S GONNA BLOW UP LIKE A SQUIRREL FILLED WITH HYDROGEN NEAR A FLAMING PAIR OF PANTS!!!!!! lol
    True_Gamer pumps 1.5V through his cpu but he has yet to be blown up or advised otherwise.
    I'd pump way more voltage through my cpu if I knew I could replace it without much trouble :D
  17. Sketchee
    Sketchee Suddenly, looters! Hundreds of 'em!
    23 Oct 2010
    Indeed, nothing to worry about here. I pump 1.5v through my nutsack 24/7 and I'm absolutely fine with it.
    Back on topic: Nice job on the CPU :thumb:
  18. jizwizard
    jizwizard Modder
    24 Dec 2010
    yep exactly. everyone thinks high voltage it will blow lol. use to pump massive volts through my old phenom and thats still going strong.
  19. faugusztin
    11 Aug 2008
    Well, his warranty is already gone anyway (because of the lapping) :).
    @Sketchee: You can't compare i7 930 and sandy bridge, they are different beasts. 45nm vs 32nm for start.
  20. Bloody_Pete
    11 Aug 2008
    No, 1.5v will kill a SB chip, 1356 chips 'could' take 1.5v...
