Bits Build your own server: Part 2
Discussion in 'Article Discussion' started by Tim S, 24 Jul 2007.
  1. Glider
    Glider /dev/null
    2 Aug 2005
    Maybe some security thing of no-ip.org? Or your firewall being confused with getting internal traffic from the external interface... Anyway, glad it worked ;)
  2. WhiskeyAlpha
    WhiskeyAlpha What's a Dremel?
    5 May 2006
    Yeah, I don't know mate, just glad it's working :D
    Thanks again for the guides Glider, much appreciated *tips hat*
    ..... Just one last thing if I may. When I create an ssh tunnel to my server remotely, what do I need to do to be able to launch webmin?
    I configured Putty with:
    hostname: xxx.no-ip.org
    port: 2222
    then setup the tunnel:
    source port: 10000
    destination: localhost:10000
    (not sure if I need to set the 'remote' radio button here)
    Then I can open the connection and login successfully. Opening a browser and navigating to https://xxx.no-ip.org:10000 unfortunately gets me nowhere.
    I've tried a few variations here and don't think I can be that far off but a quick nod in the right direction would be gladly welcomed :)
    Thanks
  3. Glider
    Glider /dev/null
    2 Aug 2005
    try navigating to http://localhost:10000 on the remote system... Then you connect to one end of the tunnel, and see what's on the other side ;)
  4. WhiskeyAlpha
    5 May 2006
    lol, it's like one of those cryptic clues in a crossword :)
    EDIT: No it's not, *slaps forehead* I'm having a blonde moment. Wrong URL.
    EDIT2: Bingo, https://localhost:10000, that got it :)
    Thanks again Glider, I'll now leave you in peace (until your next guide that is ;))
  5. WhiskeyAlpha
    5 May 2006
    Okay, so I lied... I need your help again.
    I added some users to my linux box and to the samba shares, through Webmin.
    They can all get access to their files and folders but despite following your instructions to make the 'shared' folder read/writable to all users, they are unable to move, delete or copy any of the files/folders.
    I noticed it when using WinSCP. I told my brother (who lives a good 150miles away) how to use WinSCP to download/upload files from/to the server. He was impressed :), until he realised that he couldn't actually 'do' anything with it.
    When I log in via WinSCP however, I have no problems.
    I noticed also that if I use my brothers login via SSH, the terminal only displays a '$' in the command prompt (i.e. no file paths etc) and I seem to have limited functionality.
    I assume it is something to do with the way I have setup either the new 'linux' users or 'samba' users. But I'm struggling to find any info.
  6. Glider
    Glider /dev/null
    2 Aug 2005
    Weird, could be to a number of things... I think wrong default shell and error in the samba config
    Can you provide me with the following information?
    Code:
    grep <username> /etc/passwd
    Code:
    cat /etc/samba/smb.conf
    Greets Glider
  7. WhiskeyAlpha
    5 May 2006
    Hi Glider,
    first command returns:
    (this is my brother)
    Code:
    charlie:x:1001:100::/home/charlie:/bin/sh
    (this is me)
    Code:
    will:x:1000:1000:Will,,,:/home/will:/bin/bash
    second command returns:
    Code:
    [global]
    	log file = /var/log/samba.log
    	passwd chat = *Enter\snew\sUNIX\spassword:* %n\n *Retype\snew\sUNIX\spassword:* %n\n .
    	obey pam restrictions = yes
    	socket options = TCP_NODELAY
    	null passwords = no
    	encrypt passwords = true
    	passwd program = /usr/bin/passwd %u
    	passdb backend = smbpasswd
    	wins support = no
    	dns proxy = no
    	netbios name = "XXXX" #Blanked out by me for post
    	invalid users = root
    	path = /home/shared
    	workgroup = "XXXXXXX" #Blanked out by me for post
    	security = user
    	syslog = 1
    	panic action = /usr/share/samba/panic-action %d
    	max log size = 1000
    	pam password change = no
    	log level = 3
    #Share Definitions
    [homes]
            comment = Home Directories
            browseable = yes
            writable = yes
            security mask = 0700
            create mask = 0700
    [shared]
    	comment = Shared Directory
    	writeable = yes
    	path = /home/shared/
    Cheers:thumb:
  8. Glider
    Glider /dev/null
    2 Aug 2005
    => What I tought...
    Code:
    sudo nano /etc/passwd
    And change the /bin/sh for your brother to /bin/bash
    Try adding the create mask & security mask to the share definition
    Code:
    sudo nano /etc/samba/smb.conf
    . Can you/your brother create/delete files in his home share?
  9. WhiskeyAlpha
    5 May 2006
    Nice one son.
    Now, I'm pretty sure I've already tried that tbh, but I'll give it another go.
    Oh and yes, he can read/write files in his home share, as can I.
  10. WhiskeyAlpha
    5 May 2006
    Yeah the shell problem solved :thumb:
    Still having problems with the share though those masks didn't fix it unfortunately. And I restarted the Samba server after editing.
    EDIT:
    Just noticed something very interesting. Inside my shared folder i have the following directories:
    Games
    Music
    Video
    Torrents
    For some reason only the 'Music' one seems to be giving me problems and all the others are read/writeable as expected. Now I'm even more confused. I guess the permissions on the 'Music' folder must be borked.
    EDIT2:
    I seem to now be able to create/delete directories within the 'Music' folder using my bro's login. However, I still can't 'get' any of the files off of the directory. Logging in to WinSCP as myself, I can do whatever I like. :(
  11. Glider
    Glider /dev/null
    2 Aug 2005
    Aha, that's a possibility too... Can you post
    Code:
    ls -al <path to problematic dir>
  12. Shielder
    Shielder Live long & prosper!
    26 Jul 2007
    Just to hijack the thread for a mo...
    Okay, this may be a question for part 10 ;), but I'm looking to set up a Linux server with an old system, it'll be doing file/print (possibly web) serving, but I alsoi want to use it as an authentication server for all the other boxes in the house. Is there any way of using the Linux box as the LDAP server and having the XP/Vista clients connect to it? I've got experience in connecting Linux clients to a NIS and LDAP domain, but not Windows.
    From what I've seen on the web, it can be done, but I'm not too sure how.
    TIA
    Andy
  13. WhiskeyAlpha
    5 May 2006
    Code:
    drwxr-xr-x   4 will will 4096 2007-10-28 23:31 .
    drwxrwxrwx   8 root root 4096 2007-11-08 14:27 ..
    drwxrwxrwx 137 will will 4096 2007-11-08 14:22 Compressed
    drwxr-xr-x   2 will will 4096 2007-10-28 23:31 Lossless
    I have two folders in there but only the "Compressed" one has files in it.
    Code:
    drwxrwxrwx 137 will will 4096 2007-11-08 14:22 .
    drwxr-xr-x   4 will will 4096 2007-10-28 23:31 ..
    drwxr-xr-x   3 will will 4096 2007-10-28 23:56 2K
    drwxr-xr-x   3 will will 4096 2007-10-28 23:44 A
    drwxr-xr-x   4 will will 4096 2007-10-28 23:47 AC_DC
    I see that the r/w permissions are shown on the left (though I don't profess to know what's what).
    Should there not be an entry for "charlie"?
    Also, how do 'groups' and group permissions work? I've noticed that I am a member of the group "will", whereas charlie is a member of the group "users". Could this have any bearing
    EDIT: Further speculation - could it be that maybe I "own" the folder and that's what is causing it? Or maybe created the folder as root?
  14. Glider
    Glider /dev/null
    2 Aug 2005
    Using the box as a web/printserver is no big deal... Using it as an auth server (slapd [LDAP], freeradius [Radius] or Kerberos) is possible but not that easy.
    You can also use Samba (yes Samba, the filesharing stuff) to act as an AD controller.
    I'll try to explain what you are presented with:
    The rights given to the user that owns the file, in this case will (underlined)
    The rights given to the group, in this case will (underlined)
    r = read
    w = write
    x = execute
    The world rights, to all the users.
    So try this (it opens up the whole lot quite a bit, but it'll get it working). For a more secure way of doing things, PM me, but don't worry about it for a home server ;)
    Code:
    sudo chmod -R 777 <path to folder>
    That will give every file in that folder rwx rights, to all users, so samba should be able to access it without problems every time.
  15. spartan777
    spartan777 What's a Dremel?
    8 Jun 2007
    would upgrading to xubuntu gutsy 7.10 break anything we've done in any of these two tutorials?
    and would i be able to access the server via the public address (xxx.no-ip.org) from the same lan the server is on?
  16. Glider
    Glider /dev/null
    2 Aug 2005
    It could, but I doubt it would
    Depends on your router/firewall. Sometimes it will be accessable, a lot of times it wouldn't be. On the LAN, just browse to the IP of the server and you're set.
  17. statmonkey
    statmonkey What's a Dremel?
    5 Nov 2007
    I was cruising along swimmingly until the Dblinging and I got dblung :) When I hit ctl + alt + f1 I was running through VNC since it is headless. The screen froze with a crazy pattern and VNC locked up. I rebooted from CLI through putty. Machine came right back up no worries but now when I try to VNC I get:
    Connection failed - Error reading Protocol Version
    Possible causes:
    - you've forgotten to select a DSMPlugin and the Server uses a DSMPlugin
    - Viewer and Server are not compatible (they use different RFB protocoles)
    - Bad connection
    I restarted GDM from CLI, thinking that was the problem. But I am guessing this would have something to do with SSH or something I did in the last few steps. Really would like to avoid going back through the adding back a screen etc. if possible. Any ideas what stupid thing I have done or how I can resolve this.
    Great guide by the way.
  18. Glider
    Glider /dev/null
    2 Aug 2005
    If you rebooted, and X didn't start automatically, you should restart gdm (like you did) AND afterwards restart the vnc server (through the script).
  19. statmonkey
    5 Nov 2007
    Yes, I did that before posting. I also went through the steps found earlier in this thread. I gdm seems to restart, but
    No dice. I have seen this before and for the life of me can't remember how I fixed. Think I will have to just throw a head on it and break down :( Thks anyway. O here is the out put of .trying to start the vnc server for what it is worth. I think once i put a display back on it things will be easier to sort out. Think I just keep the gui, I have space and all or maybe try NoMachine
    file will be accessed. The cookie file contains the secret key that
    allows x11vnc to connect to the desired X DISPLAY.
    - You can explicity indicate which MIT-MAGIC-COOKIE file should be used
    by the -auth option, e.g.:
    x11vnc -auth /home/someuser/.Xauthority -display :0
    x11vnc -auth /tmp/.gdmzndVlR -display :0
    you must have read permission for the auth file.
    - If NO ONE is logged into an X session yet, but there is a greeter login
    program like "gdm", "kdm", "xdm", or "dtlogin" running, you will need
    to find and use the raw display manager MIT-MAGIC-COOKIE file.
    Some examples for various display managers:
    gdm: -auth /var/gdm/:0.Xauth
    kdm: -auth /var/lib/kdm/A:0-crWk72
    xdm: -auth /var/lib/xdm/authdir/authfiles/A:0-XQvaJk
    dtlogin: -auth /var/dt/A:0-UgaaXa
    Only root will have read permission for the file, and so x11vnc must be run
    as root. The random characters in the filenames will of course change,
    and the directory the cookie file resides in may also be system dependent.
    Sometimes the command "ps wwaux | grep auth" can reveal the file location.
    See also: http://www.karlrunge.com/x11vnc/#faq
    statmonkey@server:/usr/local/bin$ *** There may be "Xlib:" error messages above with details about the failure.
    10/12/2007 17:21:30 passing arg to libvncserver: -rfbauth
    10/12/2007 17:21:30 passing arg to libvncserver: /home/statmonkey/.vnc/passwd
    10/12/2007 17:21:30 passing arg to libvncserver: -desktop
    10/12/2007 17:21:30 passing arg to libvncserver: VNC statmonkey@
    Settings:
    display: null
    authfile: null
    subwin: 0x0
    -sid mode: 0
    clip: null
    flashcmap: 0
    shiftcmap: 0
    force_idx: 0
    cmap8to24: 0
    8to24_opts: null
    24to32: 0
    visual: null
    overlay: 0
    ovl_cursor: 1
    scaling: 0 1.0000
    viewonly: 0
    shared: 0
    conn_once: 0
    timeout: 0
    inetd: 0
    filexfer: 1
    http: 0
    connect: null
    connectfile null
    vnc_conn: 1
    allow: null
    input: null
    passfile: null
    unixpw: 0
    unixpw_lst: null
    stunnel: 0
    accept: null
    accept: null
    gone: null
    users: null
    using_shm: 1
    flipbytes: 0
    onetile: 0
    solid: null
    blackout: null
    xinerama: 1
    xtrap: 0
    xrandr: 0
    xrandrmode: null
    padgeom: null
    logfile: null
    logappend: 0
    flag: null
    rc_file: ""
    norc: 0
    dbg: 0
    bg: 1
    mod_tweak: 1
    isolevel3: 0
    xkb: 0
    skipkeys: null
    sloppykeys: 0
    skip_dups: 0
    addkeysyms: 1
    xkbcompat: 0
    clearmods: 0
    remap: null
    norepeat: 1
    norepeatcnt:2
    nofb: 0
    watchbell: 1
    watchsel: 1
    watchprim: 1
    seldir: null
    cursor: 1
    multicurs: 0
    curs_mode: null
    arrow: 1
    xfixes: 1
    alphacut: 240
    alphafrac: 0.33
    alpharemove:0
    alphablend: 1
    cursorshape:1
    cursorpos: 1
    xwarpptr: 0
    buttonmap: null
    dragging: 1
    wireframe: 0xff,3,0,32+8+8+8,all,0.15+0.30+5.0+0.125
    wirecopy: always
    scrollcopy: always
    scr_area: 60000
    scr_skip: ##Soffice.bin,##StarOffice
    scr_inc: ##Nomatch
    scr_keys: null
    scr_term: null
    scr_keyrep: null
    scr_parms: 0+64+32+32,0.02+0.10+0.9,0.03+0.06+0.5+0.1+5.0
    fixscreen: null
    noxrecord: 0
    grabbuster: 0
    ptr_mode: 2
    inputskip: 10
    speeds: null
    wmdt: null
    debug_ptr: 0
    debug_key: 0
    defer: 30
    waitms: 30
    wait_ui: 2.00
    nowait_bog: 0
    slow_fb: 0.00
    readtimeout: 20
    take_naps: 1
    sb: 60
    fbpm: 1
    xdamage: 1
    xd_area: 20000
    xd_mem: 1.000
    sigpipe: null
    threads: 0
    fs_frac: 0.75
    gaps_fill: 4
    grow_fill: 3
    tile_fuzz: 2
    snapfb: 0
    rawfb: null
    pipeinput: null
    gui: 0
    gui_mode: null
    noremote: 0
    unsafe: 0
    privremote: 0
    safer: 0
    nocmds: 0
    deny_all: 0
    pid: 5769
    10/12/2007 17:21:30 x11vnc version: 0.8.2 lastmod: 2006-07-12
    10/12/2007 17:21:30
    10/12/2007 17:21:30 *** XOpenDisplay failed. No -display or DISPLAY.
    10/12/2007 17:21:30 *** Trying ":0" in 4 seconds. Press Ctrl-C to abort.
    10/12/2007 17:21:30 *** 1 2 3 4
    Xlib: connection to ":0.0" refused by server
    Xlib: Invalid MIT-MAGIC-COOKIE-1 key
    10/12/2007 17:21:34
    10/12/2007 17:21:34 ***************************************
    10/12/2007 17:21:34 *** XOpenDisplay failed :)0)
    *** x11vnc was unable to open the X DISPLAY: ":0", it cannot continue.
    Some tips and guidelines:
    * An X server (the one you wish to view) must be running before x11vnc is
    started: x11vnc does not start the X server.
    * You must use -display <disp>, -OR- set and export your DISPLAY
    environment variable to refer to the display of the desired X server.
    - Usually the display is simply ":0" (in fact x11vnc uses this if you forget
    to specify it), but in some multi-user situations it could be ":1", ":2",
    or even ":137". Ask your administrator or a guru if you are having
    difficulty determining what your X DISPLAY is.
    * Next, you need to have sufficient permissions (Xauthority)
    to connect to the X DISPLAY. Here are some Tips:
    - Often, you just need to run x11vnc as the user logged into the X session.
    So make sure to be that user when you type x11vnc.
    - Being root is usually not enough because the incorrect MIT-MAGIC-COOKIE
  20. Glider
    Glider /dev/null
    2 Aug 2005
    Here's the thing that matters :) Probably you won't have DISPLAY :0 because you restarted GDM, try:
    Code:
    x11vnc &
Tags: Add Tags
