Build Advice Can't get drivers
Discussion in 'Tech Support' started by numanoid, 26 Jan 2025.
  1. numanoid
    numanoid Modder
    26 Apr 2009
    Why the hell don't motherboard manufacturers still put a driver disk in the box, I've just installed my asrock x870e nova and I can't download the drivers as a need to connect an ethernet cable but my router is downstairs and I can't carry the heavy arse pc as I have an aneurysm of the aorta and my daughter has taken my laptop to uni...so buggered, this why they should still put a driver disk in the box even if they are older driver as it will get you up and running, tried downloading to my phone with no luck thanks
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    Try using your phone for internet via wired tethering.
    numanoid likes this.
  3. numanoid
    numanoid Modder
    26 Apr 2009
    Not done that before,how do you do that matey, thanks
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    This all depends on your phone but for the most pary they'll be similar / use similar wording.
    On my Samsung it's in settings > connections > mobile hotspot and tethering
    Just plug in your phone via usb and enable the settings, windows 11 has the drivers built in (and so do most modern Linux distros).
    GaryP, Arboreal and numanoid like this.
  5. numanoid
    numanoid Modder
    26 Apr 2009
    OK tha
    Cheers buddy, will it work with windows 10, as I've got win 10 on it until I upgrade to win 11 thank you
  6. yuusou
    yuusou Multimodder
    5 Nov 2006
    Should also be ok with win10. Give it a go.
    GaryP and numanoid like this.
  7. numanoid
    numanoid Modder
    26 Apr 2009
    Thank you buddy
  8. numanoid
    numanoid Modder
    26 Apr 2009
    Your suggestion worked a treat bud, thank you for all your help..
    GaryP, CrapBag, yuusou and 1 other person like this.
