Scratch Build – In Progress Case 6
Discussion in 'Project Logs' started by Lowsidex2, 6 Aug 2020.
  1. Lowsidex2
    Lowsidex2 Minimodder
    29 Sep 2003
    Time to get back to work
    <blockquote class="imgur-embed-pub" lang="en" data-id="4xgRogo" data-context="false" ><a href="//imgur.com/4xgRogo"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
  2. Lowsidex2
    29 Sep 2003
  3. One Works
    One Works What's a Dremel?
    21 Oct 2020
    Incredible design work. Always cool seeing people pushing their CNC routers, makes me wish I did more creative stuff when I had mine. Looking forward to seeing how you progress with the project.
  4. Lowsidex2
    29 Sep 2003
    Finally got my new GPUs. Here's a blurry picture of my (3) 8pin to (2) 12pin adapter. I stuck with 4mm sleeving to match the rest of the system so that left ugly ends I covered up with heat shrink.
    Jean R built likes this.
  5. Lowsidex2
    29 Sep 2003
    With the new GPUs I finally measured and did a final design for all the cable management.
    All of it is milled 3mm aluminum.
    Much of it is brazed together but I had lots of trouble with brazing one part weakened or broke the bond on other parts because of to much heat transfer. But in time I built up the sections.
  6. Lowsidex2
    29 Sep 2003
    I had to tread some of my wires before final assembly. I used some zip times to keep them bundled. The ugly burnt ends will be in the basement and unseen in the end product.
    Cheapskate and Jean R built like this.
  7. Lowsidex2
    29 Sep 2003
    Here are a could rough test fitting pictures. The CPU power cables not installed yet.
    One last pic before I post the final product, this time of my cramped and ugly basement.
  8. Cheapskate
    13 May 2007
    You brazed that? Holy heck, you must have the patience of a saint. Great work!
  9. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Wow! I really love that cable management guide! So sexy!
  10. Nexxo
    23 Oct 2001
