Cooling Case Fans
Discussion in 'Hardware' started by javaman, 10 Jun 2020.
  1. javaman
    javaman May irritate Eyes
    10 May 2009
    Hi Everyone,
    I could use a recommendation for a few case fans.
    one of my case fans in my pc (temp donated to folding) has developed a death rattle. Since it needs replaced i was going to take the opportunity to pick up a few more fans, probably 6 in total, to replace a couple of old fans in the case that don't sound great either and for a few other PC's
    I know Noctua are regarded as the best on the market but are they worth the price premium over something slightly cheaper for a case fan? I don't fancy £25 a fan tho they do have £16 option which I assume moves less air or is slightly louder. Ideally if there was something cheaper that was almost as good that would be perfect.
    Thanks in advance
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Have you flicked through Lenny's thread? He gives some great data and recomendations :)
    javaman likes this.
  3. javaman
    10 May 2009
    Cheers Bloody_Pete! That opening fan pron shot!
    Bloody_Pete likes this.
  4. Bloody_Pete
    11 Aug 2008
    About half way through the thread becomes more fan reviews :)
    javaman likes this.
  5. javaman
    10 May 2009
    Thanks, Bloody_Pete and Lenny! Settled for 2 5 packs of the Arctic F12 after his test of the P12's. P12 has higher static pressure while the F12 should have higher airflow according to Arctic. Dirt cheap and hopefully should have solid performance for case fan role.
  6. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Either Lenny's thread or failing that any air cooling problem can be solved by our lord and saviours noctua
    LennyRhys likes this.
  7. Bloody_Pete
    11 Aug 2008
    So very very expensive though! And they're not in black!!!
  8. MLyons
    3 Mar 2017
    They do sell black ones now. The chromax version. Expensive but I can guarantee no component in the build will outlast or out perform the fan.
  9. jsbombjack
    jsbombjack Minimodder
    14 Mar 2015
    ^seconded.
    I upgraded to chromax fans, and they are magnificent. Quiet, move a terrific amount of air. Now that they are not the usual noctua vomit colour they look lovely too
  10. javaman
    10 May 2009
    Would love to go Noctua but too rich for my blood :(
    Wonder how long before they move into the rgb game. Only accepted loudness in a fan for some people.
  11. Bloody_Pete
    11 Aug 2008
    Sorry, I meant the A12's! I need rad fans :)
  12. MLyons
    3 Mar 2017
  13. Bloody_Pete
    11 Aug 2008
    Interesting. Comparing the fains the 2k industrial one is the most appealing, high pressure and airflow with the same noise or less than my currenmt ones (although this Lian Li's have an annoying subtle rattle). I am partial to RGB in my fans though...
  14. javaman
    10 May 2009
    Received my fans :D shall hopefully get them installed tonight
