Case with a lot of harddrive bays. Suggestions?
Discussion in 'Hardware' started by afen, 17 Jun 2007.
  1. afen
    afen cyb0r p1mp
    10 Aug 2001
    Since i bought my pc in 2001, the only upgrades it's gotten is a lot of harddrives. I'm now considering to upgrade my computer, and I wonder if you guys have any suggestions about cases. It needs to be in aluminium and have minium 8 HDD bays.
  2. Colossous
    Colossous Minimodder
    28 May 2007
  3. specofdust
    specofdust Banned
    26 Feb 2005
    Coolermaster Stacker will deal with up to 16 hard disks if you relocate the front panel bit which takes up a 5.25" bay, or if you don't it'll do around 14 IIRC.
  4. Guest-23315
    Guest-23315 Guest
    Lian Li PC-343 18x 5.25" drive bays.
    Lian Li V-2000/2100 12x 3.5" drive bays.
  5. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I agree. The Coolermaster Stacker is probably gonna be yer best option for a case with lots of HDD bays ;)
    But do you really need to have all the HDD's fitted internally? Why not just stick some of them in [multi-bay] external enclosures :idea:
  6. Glider
    Glider /dev/null
    2 Aug 2005
    Coolermaster Stacker would be my choice
    A mess on your desk? or just saving the room?
  7. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    for the amount you'd spend on a stacker you might be better off to just buy a couple 500gb drives and get rid of the smaller ones.
    unless you need a new case anyways
  8. Mister_Tad
    27 Dec 2002
    a Stacker or a Lian-Li 343 with lots of 4/5-in-3s is your best bet
    Alternatively the lian-li full towers fit 12 internally if you dont fancy the idea of having them in the front 5.25 bays
  9. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
  10. cjmUK
    cjmUK Old git.
    9 Feb 2004
    Seconded.
  11. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Lian-Li V-2000. 12 hard drives without touching your 5 1/4" bays, and with 3-to-4 adaptors, you can get 20 hard drives in and still have space for a CD-ROM. And it looks fabulous as well.
    (And the stacker is steel, not aluminum like the OP wants)
  12. identikit
    identikit Minimodder
    5 Jun 2004
    It's all about being resourceful...
  13. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    I see 24 hard drives lol. How much storage?
  14. identikit
    5 Jun 2004
    No idea, I saw that PC posted ages ago. Guessing not much storage as it's old. Although I do know someone with 24 750Gb HDDs, the gigs lost by allocation and lies is around 500!
  15. ConKbot of Doom
    2 Jul 2003
    a terabyte :lol:
    EDIT: found this... online from days past...
    http://www.g4tv.com/screensavers/features/38895/Build_a_Terabyte_System.html
    how to make a terabyte system with 8 drives in 1 computer... :hehe: granted my 1.2 tb storage server has 6 drives in it, 1 is the system drive which I dont count towards the space, 1 is a hot spare, and 1 is taken up by the raid5 parity. :p
