Scratch Build – In Progress CaseMod: TARDIS - FINISHED!!!
Discussion in 'Project Logs' started by Pfaffen, 19 Aug 2012.
  1. Cheapskate
    13 May 2007
    There's always the option of "owner distressed." -Or "shipping distressed." The post office seems to be pretty good at it. Just pack it in scouring pads before you send it out.:D
  2. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Great point! Since it has to go to Australia, it would have plenty of time!
  3. oliverr97
    oliverr97 New Member
    31 Jul 2011
    This is a very interesting case mod, good luck to you :)
  4. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    On to the small parts. Each is 1/8 in wide and is half lapped to fit.
  5. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Now that they are dry, its time to clean them up.
    Clipping off the long edges on all the sides...
    Some sanding...
    and more sanding...
  6. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Here are the windows sitting in the door frames
    Now to cut out the holes
    One down... 7 to go...
  7. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Keep the updates coming :thumb:
  8. vrrox
    vrrox New Member
    27 Apr 2009
    Excellent idea for a mod!! Very much looking forward to seeing how this turns out :D Good luck! :thumb:
  9. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Thanks!... Been traveling a bit, so progresss has slowed.
  10. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Here are the posts and doors.
    Here is a shot of the doors with the sign dry fitted.
    Here is the inside looking out. The doors are mounted.
  11. SuicideNeil
    SuicideNeil New Member
    17 Aug 2009
    Hmm, it looks bigger on the inside..
    Great work dude, loving it so far :)
  12. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Thanks!... it is bigger on the inside. :)
  13. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Time for some glue-ups
    Make sure the computer it was designed to hold fits!
    Top view without the roof.
  14. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    First coat of primer
  15. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Compared to the model.
  16. Cheapskate
    13 May 2007
    OOOF. It always hurts to see the primer go on.:(
  17. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    I know! :wallbash:
  18. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Here we are in the spray booth.
    First can of paint down... two more to go...
    Well ok, 1 and a half to get here.
  19. Karrek
    Karrek Member
    7 Jun 2011
    Nice Paint Booth
    your paint booth caught my eye. Is the box fan exausting air (drawing air in through the furnace filter)? Do you have it on as you are painting, or just afterwards to help the item dry? I'm intrigued - and want to build my own now.
    Great paint job - I agree that it is a shame to paint the beautiful wood, but it wouldn't look right if it wasn't blue. great work so far. I'm interested to see how you fit the components...
  20. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    I use it to pull air through the box. While I am painting, I have the front open and the fan pulling air. To dry, I pull down the front flap and seal it. Causing the Air go go through the filter.
