drive bay is finished, now only makinjg the front plate, grey smoke acryl, here you see the connectors for power power led reset and reset switch cpu and pciE disable, ecp connector to mobo, and in front the Evga EVbot connector, debug lcd and clear Cmos switch :
what a bewildering mind boggling project ....it gave me a headache just looking at the wiring Top work
Busy on the clean front plate of grey smoke acryl. Now made the EVbot connector in place, only the dvd cut-out and clear CMos and offcourse the drive bay PSU needs some fresh air to. The outside needs to be finished at the end :
i need 125 votes ASAP in each category for getting extra points, please vote for Custom tec for i7 http://forum.newmodcity.com/viewtopic.php?f=116&t=995 Chiller's hybrid SR-2 http://forum.newmodcity.com/viewtopic.php?f=116&t=996
here a little update of my front plate, only need to find a nice grid to put in there so it comes nice untill the front :
i made my eject button for the dvd drive in red acryl with a red SMD-Led 0805 behind it. I can switch easy between hdd activity led or Power led : Kynar wire for SMD, small wire with a very small hole under the drive :
little update : Coolingpaste is used : Liquid Ultra, temp sensor by every cpu, Adjust the mounting with red smoke acryl voor more pressure on armaflex and for visual effects, start to cut also some tubing Norprene on size, only waiting for next orders to arrive of tube clamps, 3mm red led's, and some more stuff. The first triple kit memory is also ordered : Corsair Dominator GT 12Gb triple kit 2000Mhz CL9, where there will come 4 kits on the mobo of these. enjoy the pics :
Amazing mate.. Truly amazing Im so looking forwards to seeing this this finished and some benchmarks running
