News Chrome to prerender search result pages
Discussion in 'Article Discussion' started by arcticstoat, 15 Jun 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Mentai
    Mentai What's a Dremel?
    11 Nov 2007
    Other than performance on low powered devices, this also isn't great for bandwidth usage on terrible internet plans (think costs of 3/4G data in most countries). I think as long as it's optional it's a good idea.
  3. mclean007
    mclean007 Officious Bystander
    22 May 2003
    There are, I think, two issues here. First is that it has the potential to chew bandwidth, which is fine on an all you can eat tariff or, relaistically, pretty much any home broadband connection where the incremental data use is likely to be negligible, but unattractive for pay as you go or capped mobile internet and ESPECIALLY for roaming. Secondly, it means your browser will register hits on sites you might not want it to (which has privacy implications) and might not actually visit (which may skew their traffic stats). As long as it's optional, however, and it only prerenders first party HTML and images, not flash and not third party content, I don't see why it's a problem.
  4. glaeken
    glaeken Freeeeeeeze! I'm a cawp!
    1 Jan 2005
    Maybe they should first fix their results to actually pertain to my search...
  5. Fredrics
    Fredrics Hmm...
    31 Dec 2007
    They have been preloading data for ages, although I dont know what exactly it is they where preloading. However I guess they are now preloading and prerendering the data.
  6. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Realistically if it's just pre-rendering the HTML and not pulling down large images / flash / java content then bandwidth wise it shouldn't be too much of a problem. Definitely would want a switch on it though. Maybe they could use ISP detection to i.d. which connections they should run it down automatically. Don't do it on 3, Vodafone, Orange, T-Mobile, O2 (if they can split the home and mobile traffic), AT&T, Verizon etc etc. And then put it on by default for desktop browsers for other ISP's. Either way I'd have it disabled by default for Mobile Google, but with the option to switch it on, it would probably help page loading quite a lot on more CPU bound mobile phones
  7. Deders
    Deders Modder
    14 Nov 2010
    Wouldn't caching the page pretty much do the same thing? and what happens if you search for something and there's a new page that might be relevant to your needs, but you don't see it because Google says so?
  8. PQuiff
    PQuiff What's a Dremel?
    7 Sep 2001
    Until it uses aero. Not interested.
  9. Xir
    Xir Modder
    26 Apr 2006
    But where's the speedup on that? :D
    Another nice plan by people to whom bandwidth is not a problem.
    Preload stuff you may not need, plaster everything in the cloud...no problem on the T1 connection back at google HQ.
    As the trend (imho) is going towards mobile internet, bandwith is:
    either a problem or
    a serious cost factor
    :D
Tags: Add Tags
