Other Cleaning out a pc
Discussion in 'Hardware' started by MarkW7, 22 Feb 2009.
  1. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Hello,
    We've had the family pc for years now - i opened it up today and nearly died at the site of the ammout of dust! It's got into everything.
    Is there a cheap / effective way of doing this.
    Thanks :D
  2. O O 7
    O O 7 What's a Dremel?
    7 Dec 2008
    Use air spray cans and a vaccum cleaner! (be very careful)
  3. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    I realized that buying those compressed air was a waste of money, I just go straight to using the vacuum and let the vacuum suck all the suck off the fans, corners, heatsink. I let the vacuum's suction spin some of the fans around for a good 30 seconds, the fans spin really really fast taking out all the dust under them, Works better than a compressed can of air IMO.
  4. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    So a vaccum is better than compressed air, what do you mean by be very careful?
  5. O O 7
    7 Dec 2008
    Ok.
    I meant use the vacuum cleaner first, then try some compressed air for any dust remaining.
    When using the vacuum cleaner, be VERY careful not to hit anything with the nozzle, you could potentially break small capacitor stuff and have the vacuum cleaner suck it up! YUM!
    Use the brush nozzle gently, and (if your vac cleaner has it) use low power.
  6. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Is it worth buying compressed air?
  7. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    I vacuumed a bit off my gfx card and it never worked again :(
  8. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Yep, don't touch any components with the nozzle of the vacuum cleaner (could possibly physically damage them or release a static charge through them).
    I've been cleaning my PC's with a vacuum for all the time, and still working fine.
    Get the most of the dust out with the vacuum, and if something is still remaining, blow them out with compressed air (as O O 7 said).
    Oh, and you might want to check out the PSU, it's propably full of dust aswell. Just remember not to touch anything inside it.
  9. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Do you recomend getting compressed air to get into them little places - were would i get it from?
  10. culley
    culley What's a Dremel?
    12 Jul 2006
    Buy an anti-static vacum and then you wont have to worry about frying the parts.
  11. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Compressed air can be bought from PC or camera shops, even PC World & Maplin.
  12. KillerLettuce
    KillerLettuce custom title
    15 Jan 2009
    I use compressed air- either from a can or an air compressor.
  13. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    How much is a can.
  14. davidfield375
    davidfield375 Hardware Mods
    3 Feb 2009
    I would forget wasting money on the compressed air, unless you want to clean your keyboard, doing the keyboard with a vacuum normally results in a few keys disappearing! I used to clean my PC every summer with the vacuum, never once had any problems.
  15. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    I go the compressed air route myself, I would clean out the inside of my comp. every 2-3 months, so I would get a few goes out of a can, so quite happy with that, wouldn't be too keen using a vacuum cleaner on my PC Case (because of static mostly), but each to their own..
    ________
    KINKYPORN cam
  16. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    jbloggs. how much is a can.
  17. DorkSterr
    29 Nov 2008
    They cost a maximum of $10.
  18. jhanlon303
    7 Sep 2006
    I use the canned air about every month or two at the most. While we are discussing this cleaning stuff, is it better to keep PCs on the floor or up higher to stay away from the house heat and air flow?
    john
  19. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    $10 is around £5 i think as im in the uk, anyone know shops in the uk that sell it.
    As for pc placement im not sure probably better off the floor maybe on a desk but not high up - heat rises and you wouldn't want it to fall - maybe 0.5m or so off the floor?
  20. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    I'd use a stiff paint brush, a room fan, compressed air (from your lungs ;)) and if necessary a can of proper compressed air.
    JHanlon, If you put it on a desk it should stay more dust-free, unless the dust is in your ceiling ;) But in a carpeted room probs best to be on the desk rather than the floor.
    Also, there is probably greater airflow potential (read: exhaust from case) on top of a desk.
    MarkW7 - try a DIY shop or most computer shops.
    Also, you don't really have to worry about rising hot air unless it is seriously hot. Height in the room (purely for temperature change) probably won't make any difference to ambient temperature, or maybe 2*C if you live in a tower, in the summer ;)
